Phantom Toilet Leak - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-20-2010, 02:29 PM   #1
Phantom Toilet Leak
We have a constant and distinct drip-drip-drip inside the basement waste pipe that hooks directly the first floor master bedroom toilet. No water on the bathroom floor, and no phantom flushes. The shower drain is also hooked to same waste stack, but the drip occurs all day and night long after showers are done. Any ideas what needs fixed? Last plumber that looked at this only replaced the flapper. Thanks!
lucasrt is offline   Reply With Quote
Old 03-20-2010, 04:01 PM   #2
the Musigician
DangerMouse's Avatar
Hi and welcome to the forum.
Sounds to me like the flapper is still the culprit. Listen VERY carefully with the lid off and see if you hear anything.
Then take a stick and gently push down on the flapper to be sure it's sealing tightly. There might just be some crud under it the plumber missed too....
DM
Old 03-20-2010, 05:35 PM   #3
Rewards Points: 152
Could be the tube running from the inlet valve into the overflow tube, I've seen those leaking/dripping before.
burnt03 is offline   Reply With Quote
Old 03-20-2010, 06:17 PM   #4
DIY staff
Rewards Points: 7,174
Shut off the water to the toilet---See if the water level in the tank changes overnight.
no change--flapper is good. see if the dripping noise has stopped .
Old 03-20-2010, 09:04 PM   #5
Rewards Points: 1,088
Overflow tube discharges into the bowl though, so there shouldn't be a constant drip drip, eh?
handy man88 is offline   Reply With Quote
Old 03-20-2010, 11:33 PM   #6
Rewards Points: 352
If the bowl is full every drop that drips goes down the drain
plumberinlaw is offline   Reply With Quote
Old 03-21-2010, 01:45 PM   #7
Doing it myself
Alan's Avatar
Rewards Points: 2,086
2 reasons this would cause a problem. Fill valve is leaking slightly enough to allow just the bowl primer to drip, OR, the tube for bowl primer is too long. If it is below the water level in the tank, it will siphon.
Journeyman Plumber
Old 03-21-2010, 01:56 PM   #8
the Musigician
Posts like this one really make me itch to go LOOK and see what is happening.
The process of elimination is SO much quicker that way! lol
Here's hoping one of us has the solution.... (oh'mike still has the best idea for troubleshooting it I think.)
I love it when one of us helps solve these problems.... makes me all tingly inside... Po)
DM
Leak behind toilet majorchamp Plumbing 4 01-28-2012 08:00 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
toilet leak after replace new wax ring druffino Plumbing 4 07-17-2008 11:31 PM
Toilet problem - Leak in Pipe underneath jackbean Plumbing 7 05-28-2008 11:33 PM
