Pex Valves - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-24-2009, 01:52 PM   #1
Rewards Points: 270
pex valves
I'm going to try my hand at PEX for my addition - pretty simple runs (1 bathroom with standard fixtures, 1 kitchen sink)
in the past where I've used copper, I've always clamped the last run of pipe (e.g. inside the wall, against the stud) close to where it exits the wall. That way the shutoff valves stay very secure (nothing flopping around under the sink once the valves are in, etc.)
starting to sketch this out and look for parts, etc. - question comes to mind - how do I do this with PEX? are there plastic clamps - and even so, wouldn't the valves still just kinda flop around loose (the PEX pipe feeding out from the wall is not really rigid like copper).
as you can see, total PEX DIY here - thanks for any advice...
rtoni is offline   Reply With Quote
Old 02-24-2009, 02:38 PM   #2
RippySkippy's Avatar
I use the preformed copper stub outs that convert from pex to copper, soldered to a bracket and ended up with something below. I'm sure there are many methods...but this works well. When you're ready to put the stops on...you can use either compression or sweat...I used sweat...and didn't have any problems.
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Old 02-24-2009, 03:34 PM   #3
Remodeling Contractor
use a pex shower 90. Fasten it to a block behind it and use a brass nipple to the shut off valve.
check out the new ball valves! wombosi Plumbing 7 02-03-2009 09:00 PM
why do my 1/4 turn valves leak? moondog111 Plumbing 1 12-07-2008 11:09 PM
leaking valves - DIY help wombosi Plumbing 4 11-17-2008 08:32 PM
shut off valves on cast iron radiators bdw2677 Plumbing 2 10-21-2008 07:07 PM
Shut Off Valves Coach Gordon Plumbing 2 04-24-2006 03:13 PM
