Pex - Two Questions - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-20-2010, 09:09 PM   #1
Rewards Points: 150
Pex - two questions
First, I noticed there are red and blue pex coils at the local Home Depot. Are these just for "hot" and "cold" or are there differences in the quality/specs?
Second.. I have an exterior garage and am planning to run a line for water from the house. I hope to eventually plumb in a bathroom with toilet, tub, sink. I'll also (more immediately) have a couple water spigots for garden hoses. Should I use 1/2 or 3/4" pex?
sheslostcontrol is offline   Reply With Quote
Old 09-20-2010, 10:48 PM   #2
lloydb's Avatar
It's the same stuff, the colors just make things easier to keep track of.
I'd run 3/4 to the garage if you are going to do the tub and sink thing and have a water heater out there. For the 3/4 line to the garage to be worthwhile, you should tie into a 3/4 line for supply, i.e. out in the yard before it gets to the house.
I've done plenty of these. Find the water line in the yard by hand shovel, drop a trencher stinger in the ground next to it and take off towards your out building...after you get everything marked of course.
Broken Arrow hvac Broken Arrow Air Conditioning
lloydb is offline   Reply With Quote
Old 09-20-2010, 11:16 PM   #3
lloydb's Avatar
Btw... A good way to bring that water line into your garage would be to rent a hammer drill with a 1 1/8" x 36" bit, and pick a place next to the exterior wall where you'd like for the line to come in and drill out at maybe a 70 degree angle. This angle with a 3 foot bit usually gets you out of the building, through the footing and its still pretty deep.
I usually do some measurements and back the trencher up to the building and cut a slice where I expect my bit to come out.
The Following User Says Thank You to lloydb For This Useful Post:
sheslostcontrol (09-20-2010)
Old 09-20-2010, 11:20 PM   #4
Rewards Points: 150
I'm also running some conduit for low-voltage wiring (coax, ethernet and security).. I think the conduit I'm using is 2". Any issues with running the pex along side the conduit when buried in the ground?
Old 09-21-2010, 12:12 AM   #5
crankcase's Avatar
Shouldn't be a problem running them along side, but if freezing is a concern make sure the water line is below frost line. I have to have mine down a minumim of 42" but I'm at 60" to be safe here in MN. I also have a boiler valve tied in after the shutoff to blow out the whole works if I turn off the heat in the garage.
crankcase is offline   Reply With Quote
Old 09-21-2010, 07:35 AM   #6
Just call me Andrew
Rewards Points: 1,020
I know some things like valves are better purchased at a plumbing supply store, not HD or Lowes. Not sure if this also applies to tubing.
Andrew
secutanudu is offline   Reply With Quote
Help How to Wire Bathroom "Fan Heater Light Night-light" unit, and questions Tryvidy Electrical 9 06-18-2012 02:37 PM
Newbie with questions about a 4 ton rheem nissan4x4 HVAC 4 05-24-2010 11:53 PM
How thick should my thinset be? yummy mummy Tiling, ceramics, marble 20 09-28-2009 12:36 PM
Aluminum-wired house, questions LMH Electrical 2 05-24-2009 03:06 AM
Laminate wood floor layout questions nathan.tran Flooring 4 08-30-2008 10:56 PM
