Pex Tubing Vs Copper Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-31-2012, 03:49 PM   #1
pex tubing vs copper pipe
I recently changed out the tub faucet in my master bath, and switched it from copper pipe to pex at the same time. Since then I have such dismally low water pressure, it takes 25 minutes to fill the tub. What is the most likely source of the problem?
StillRygah is offline   Reply With Quote
Old 10-31-2012, 04:44 PM   #2
funfool's Avatar
Rewards Points: 534
Not the pex. Would be something with the valve. Modern valves are designed to be low flow to conserve water, they usually have a limit setting so you do not scald yourself with hot water.
Simply more complicated then the older valves. I would suggest pulling out the directions and reading through it to see the options and settings you have.
funfool is offline   Reply With Quote
Old 10-31-2012, 04:50 PM   #3
Rewards Points: 13,446
Trash got knocked loose and is plugging up the posts in the control valve.
Anti scald valve has trash in it.
1/2" Pex was used instead of 3/4" (I've used 1/2" many times for the supply and never had an issue, but we have no way of knowing how long your runs are)
Compression fitting with copper tubing for dishwasher DK75 Plumbing 4 04-27-2012 06:47 PM
Buried Copper LP Tubing Earnie Plumbing 1 02-22-2011 08:22 PM
Bernoulli's Principle, increase 3/4" pipe to 1-1/4" or 1-1/2" copper ChrisDIY Plumbing 14 09-18-2010 09:49 PM
copper pipe vs pex I'm in trouble Plumbing 4 06-27-2010 11:42 PM
copper strap around copper pipe? analogmusicman Plumbing 3 06-04-2008 10:55 AM
