-   -   pex tubing vs copper pipe (http://www.diychatroom.com/f7/pex-tubing-vs-copper-pipe-161753/)
StillRygah 10-31-2012 04:49 PM
I recently changed out the tub faucet in my master bath, and switched it from copper pipe to pex at the same time. Since then I have such dismally low water pressure, it takes 25 minutes to fill the tub. What is the most likely source of the problem?
funfool 10-31-2012 05:44 PM
Not the pex. Would be something with the valve. Modern valves are designed to be low flow to conserve water, they usually have a limit setting so you do not scald yourself with hot water.
Simply more complicated then the older valves. I would suggest pulling out the directions and reading through it to see the options and settings you have.
joecaption 10-31-2012 05:50 PM
Trash got knocked loose and is plugging up the posts in the control valve.
Anti scald valve has trash in it.
1/2" Pex was used instead of 3/4" (I've used 1/2" many times for the supply and never had an issue, but we have no way of knowing how long your runs are)
