PEX Tubing For Hot Water Heat - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-16-2011, 12:50 PM   #1
PEX tubing for hot water heat
Is pex tubing legal for use in a mixed use (commercial-residential) building for hot water heat?
glederman is offline   Reply With Quote
Old 12-16-2011, 01:07 PM   #2
Rewards Points: 5,336
Where are you located. This might be a locale question based on where you live.
Have you spoken to the local building dept?
Ron
B. Franklin 1759
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 01:01 AM
Hot water heat under my floor? lwendt Flooring 0 12-12-2010 02:58 PM
Using the heat generated by the hot water chimney? Red Squirrel HVAC 17 10-10-2010 03:26 PM
