Pex tubing & compression fittings
Hi;
I just installed a new sink faucet. It uses Pex tubing for the supply. The tubing and compression fittings with the nuts were already attached to the faucet. When I made the compression connections to the shutoff valves, I had no leaks, but I am thinking that I might have over-tightened the nuts a bit. The instructions (which I read very carefully, except for the part about how much to tighten the fittings) said to tighten one turn past finger tight, not to over-tighten. It is very difficult to know what "finger tight" is with these old valves, because the nuts don't thread on so easily as they would on new valves. I did tighten pretty hard, but not as hard as I could have<g> There are no leaks, but I am just wondering whether, if the nuts were over-tightened, the connections could start to leak later on, or would they have leaked right away. I have no intentions of un-tightening the nuts so that they are definitely not over-tightened, because I KNOW that they WILL leak after I do that. It's under the sink, so I have access to check them once in a while if I feel the need to, but I always tend to second-guess myself after doing a job that I have not done many times before. BTW, there is plenty of the PEX supply lines available (I had to loop it) in case I need to cut and re-do the connection at a later date. Thanks for your advice. FW |
my quess is that it wouldve leaked right away as if you pinched the line.
So, the word is: "Leak now, or forever hold your spritz" FW |
| All times are GMT -4. The time now is 11:47 AM. |
