Pex Tubing On Compression Fittings - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-23-2009, 11:11 PM   #1
Rewards Points: 1,088
Pex Tubing on Compression Fittings
How often has anyone seen or done this? Are there special adapters for Pex to be used on compression fittings for a stop valve used for a sink?
handy man88 is offline   Reply With Quote
Old 01-24-2009, 07:00 AM   #2
I haven't done this application but I have seen the adapter fittings
from pex to other pipes for dishwashers and drinking water and fridge lines. Pex had specific fittings when I looked at it two years ago.There
were several suppliers making PEX like piping and several different fittings specific to the brand. They may have become more standardised by now.... take a photo or brand of the fitting you are adapting to and look at the "pex" tubing for printing to identify if it is PEX or another brand just in case
Chemist1961 is offline   Reply With Quote
Old 01-24-2009, 08:27 AM   #3
No, but they sell stop valves with pex adaptions already on them, you would just need a 1/2" crimper(i believe you can rent a pair) and some crimp rings, then you can just run your standard 3/8" supply line from the compression fitting to the faucet.
zosoplumber is offline   Reply With Quote
Old 01-24-2009, 09:30 AM   #4
It's hard to tell by just looking at the brass 3 way stop valve, but it's definitely Pex tubing coming out of the compression nut. The tubing is labeled as such and is made by Merflex.
http://www.mercuryplastics.com/refrigerator.html
Here's more general info:
What joining systems are available?
There are several methods of connecting PEX, all of which involve mechanical fittings. There are two approved standard specifications for PEX connections: ASTM F 1807 and ASTM F 1960. Both reference mechanical insert fittings. The crimp fittings specified in ASTM F1807 are the most widely used. Other fitting systems, including insert and outside diameter compression fittings, are also available. PEX cannot be joined by solvent cement or heat fusion methods.
http://www.ppfahome.org/pex/faqpex.html
http://www.homedepot.com/webapp/wcs/...ctId=100129551
Intermittant total compression loss? johnd393 Automotive Repairs 7 07-26-2014 12:08 PM
help with leaky compression fittings wombosi Plumbing 9 01-23-2009 06:25 AM
compression fitting Barry J Plumbing 3 11-21-2008 12:19 PM
Metric compression fittings ??? rutalkn Plumbing 3 11-27-2007 11:43 PM
iron pipe fittings farrington135 Plumbing 1 07-13-2007 09:16 PM
