PEX Tubing - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-05-2008, 10:06 AM   #1
PEX Tubing
What type of PEX Tubing is best for an underground run?
G3Aloha is offline   Reply With Quote
Old 08-05-2008, 10:44 AM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Pex is pex, type does not matter.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 08-05-2008, 10:51 AM   #3
Mahalo
Thanks, that what I thought but had to make sure.
Old 08-05-2008, 11:00 PM   #4
Doing it myself
Alan's Avatar
Rewards Points: 2,086
I personally would prefer the type without the metal bands for under the dirt, but thats just me.
Journeyman Plumber
Old 08-06-2008, 05:17 AM   #5
Send a message via AIM to Marlin
I've never seen a problem with the stainless bands being buried. Copper I have never seen but would imagine it's a little more prone to corrosion then SS.
Marlin is offline   Reply With Quote
Old 08-06-2008, 09:16 AM   #6
Licensed Master Plumber
mstplumber's Avatar
Rewards Points: 150
We use Sharkbites underground with no problems to date.
Mstplumber
Check out my goofy video for my new toilet repair book.
mstplumber is offline   Reply With Quote
Old 08-07-2008, 04:13 PM   #7
DIY Junkie!!
Rewards Points: 182
I'm considering a rather large scale plumbing improvement to a SW KS vacation home (yep, I'm the guy who spent a small fortune in retrofits to be able to install a whole-house HWOD ). The plans for NEXT summer include a new supply line from the meter to the house, replacing the water supply pipes with a non-metallic product (more on that to come--read on), and installing underfloor radiant heating from the basement where I have full access to the ground floor's floor joists.
I've read PEX expands almost 2' for every 100' of product when it heats up (causing noises within the house from the expansion), so I plan on using Onix tubing for the radiant heating (and, if possible, for the water supply lines). Onix seems to be more costly until you find out the product does not require any heat transfer plates, and the fittings require very inexpensive tools (if you already have an automotive torque wrench that is calibrated in in/ft, you're ready to go!!!).
My question at this point regards the supply line from the meter to the house--this Onix product looks for all the world like a very high quality, 5 ply garden hose. It's so flexible you can double it back upon itself using only about 12" of tubing--so, I'm wondering if it will resist collapsing from the weight of the soil above it when it is buried 5' underground!!!!!
Does anyone have any experience with this product in this application??
Thanks in advance for whatever advice you can offer!
Dugly
YerDugliness is offline   Reply With Quote
Old 08-08-2008, 11:05 AM   #8
mstplumber's Avatar
Rewards Points: 150
I don't think the Onix is Code approved for either the water supply or distribution piping. I would definitely make sure before installing it in one of those applications
Mstplumber
Old 08-08-2008, 11:20 AM   #9
DIY Junkie!!
Rewards Points: 182
Thanks for that bit of advice, mstplumber! I'm going to call the company today to discuss the radiant heat system, will certainly ask about using it for supply lines, also.
BTW--check your inbox in a few minutes, I'm getting ready to PM you regarding a totally different issue .
Dugly
Copper tubing for icemaker? BigJimmy Plumbing 15 09-11-2011 02:23 PM
How Do I uncoil Pex Tubing without an Uncoiler? DonM Plumbing 10 09-20-2010 05:11 PM
Advice - PEX tubing ! sandy2982 Plumbing 4 04-16-2008 01:51 PM
What is PEX-a tubing and can I use Push-N-Turn with it? curls00 Plumbing 2 07-31-2007 10:05 PM
Insulation of pex tubing? user007 HVAC 2 12-21-2006 09:44 PM
