Pex Transition Underground - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-23-2013, 06:13 PM   #1
Rewards Points: 152
Pex transition underground
I need to make my PEX transition to PVC outside my building. Common sense told me that the steel crimp rings would not be acceptable underground. After internet searching I found that to be true. The only fitting I have available locally is a WATTS P615 female adapter:
I cannot find any spec that says this is acceptable. If I need to get a Sharkbite fitting, I'll have to drive 50 miles to the closest plumbing store. I don't remember if Lowes had Sharkbites or not.
Attached are the rings I've been using (Apollo) and also a picture of my proposed hookup outside my slab. This is a garage with a toilet and lav only. I do have to have this inspected for approval after I'm done. I'm hoping I don't have to drive 100 miles round trip for a $5 part
Pex transition underground-pex-connection-002.jpg   Pex transition underground-pex-connection-001.jpg   Pex transition underground-pex-connection-003.jpg
n175h is offline   Reply With Quote
Old 02-23-2013, 06:23 PM   #2
Rewards Points: 13,690
Go back and add your location.
No way would they let me install water pipes that shallow.
I also would not have used those PVC shutoffs. They get harder and harder to shut off as they get older.
Any shut off needs to be in a box not just buryed under ground.
http://www.bing.com/images/search?q=...electedIndex=7
I believe you'll find those rings are not steel, there brass with a black plating on them. hit one with a file and see.
Old 02-23-2013, 06:29 PM   #3
Rewards Points: 152
I thought about that when I looked at the picture. I'm in S TX. No freezes down here. Shallow burial is ok.
Also, I will get a box. Just haven't bought it yet.
If they are brass are they acceptable underground in this application? I can't determine from their specs if they can or can't be used.
Old 02-23-2013, 06:36 PM   #4
I do all the time in this area and it freezes here.
Old 02-23-2013, 06:39 PM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 662
Call your inspector Monday. It doesn't matter what the specs says. It's his/her OK that counts
Old 02-23-2013, 10:15 PM   #6
Rewards Points: 152
Won't work. He will say, "if you don't know, call a plumber". Makes it tough for a weekend warrior like me.
Total Degrees of Bend in Underground PVC Conduit tedallen Electrical 12 03-29-2012 08:02 PM
underground electical lines BlueBSH Electrical 11 02-10-2012 03:52 AM
Driveway culvert to underground pipe zrooster99 Landscaping & Lawn Care 4 06-25-2011 12:42 PM
Tiling entryway - proper transition for this scenario? Scott99999 Flooring 5 12-22-2009 12:12 AM
Engineered Hardwood: Inlaid transition? SteveSmith98 Flooring 6 03-24-2009 11:21 AM
