Pex Toilet And Faucet Hook Up - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-30-2013, 11:56 PM   #16
Maryland
Originally Posted by kryolla
perfect thanks..can I put a sleeve over the copper so I don't see copper coming out the wall for the toilet supply line
http://www.pexsupply.com/Wirsbo-Upon...6-OD-4273000-p
You can stub the pex out of the wall and then use the above sleeve. This eliminates all joints between the supply and the stop valve and you don't see the pex.
Pittsville is offline   Reply With Quote
Old 10-31-2013, 06:36 AM   #17
Rewards Points: 13,450
If he uses the stub out I suggested there will not be any floppy Pex sticking out of the wall to deal with.
That's a pet peeve of mine when I see where someone cheaped out and just has the Pex sticking out of the wall. It looks cheap and makes it harder to change the valve when it fails.
two issues: toilet and faucet BDWeller Plumbing 2 05-05-2013 07:11 AM
Install new faucet with compression fittings to larger copper supply lines cwb124 Plumbing 7 02-27-2013 04:11 PM
Can high water pressure cause a toilet to run? sirienne Plumbing 6 01-13-2013 07:58 PM
clawfoot tub faucet install autx790 Plumbing 8 06-04-2012 07:18 PM
Can my corner sink (and toilet) be salvaged?? wombosi Plumbing 3 11-10-2008 10:44 AM
