PEX Through Foundation Wall - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-21-2011, 05:10 PM   #1
I can fix that!
Rewards Points: 35
I am trying to figure out the proper way to run a 1" PEX water main through my foundation wall 3' below grade. I understad I should use a sleeve, but don't know how to seal everything up. My thoughts are to bore a 2" hole and put in the largest piece of PVC that will fit. From there I am stuck. Should I try to get some hydraulic cement in between the PVC and the Concrete? What should I fill/seal the area between the PEX and the PVC with? Or, is there a product out there for this application that I cannot find?
kuhlman is offline   Reply With Quote
Old 12-21-2011, 06:42 PM   #2
Civil Engineer
Rewards Points: 4,762
Expansive foam works fine (Great Stuff).
The Following User Says Thank You to Daniel Holzman For This Useful Post:
plummen (12-22-2011)
Old 12-22-2011, 09:09 AM   #3
I can fix that!
Rewards Points: 35
Does foam like "Great Stuff" creat a waterproof seal? It will be about 3' below grade so some pressure may be present during heavier rains.
Old 12-22-2011, 09:15 AM   #4
Civil Engineer
I have used Great Stuff to seal several plastic pipes penetrating through an 8 inch thick concrete wall, seemed to seal perfectly. I also used it to seal a plastic conduit for electrical through a wood sill, that worked well too.
kuhlman (12-22-2011)
Old 12-22-2011, 11:08 AM   #5
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,214
Duct seal
http://www.google.com/products/catal...ed=0CHUQ8wIwAA
Coastal South Carolina
Old 12-22-2011, 01:14 PM   #6
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
use the great stuff to seal around inside of the sleeve to give the pex a little expansion room,then tar around outside like the rest of your foundation.
3' seems a little shallow to me,we normally go closer to 5' around here to get below frost line
plummen is offline   Reply With Quote
Old 12-22-2011, 09:27 PM   #7
Msradell's Avatar
Rewards Points: 210
3' out his way should be below the frost line. They get a lot of rain out that way but overall it's fairly temperate as far as temperatures go. Out where you are it gets a lot colder and stays that way a lot longer!
Msradell is offline   Reply With Quote
Old 12-23-2011, 12:51 PM   #8
I can fix that!
Rewards Points: 35
Yep, 3' is where my old galvanized main is at. Would you just bury the PEX, or have it inside PVC and bury it? Or, just bury it in sand--although my fill dirt will be clean.
Tags
basement , concrete , plumbing , supply
New foundation for bathroom floor and exterior wall studs JayG Building & Construction 2 07-11-2010 01:25 PM
Foundation or Load Bearing Wall Issue? sheribaby Building & Construction 3 04-14-2010 05:07 PM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 10:32 AM
Removing spine wall beko Building & Construction 12 02-02-2010 01:15 AM
Free standing block wall foundation 3DPiper Building & Construction 4 10-19-2006 08:42 PM
