PEX Supply Line Insulate Or Not? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-27-2013, 06:43 AM   #1
Send a message via AIM to Rich Send a message via Yahoo to Rich
PEX supply line Insulate or not?
Replaced galvanized supply lines throughout home with new PEX. PEX is not run in a manifold setup but more of a trunk and branch setup. There will be on-demand recirculation pumps on the 3/4" hot water loops at the water heater (not under sink). I planned on sliding on 1/2" thick foam rubber type insulation as I cut in the branches off the trunk lines. However, it was brought up to me that the pipes will all run through "conditioned space" as there are heat registers in all the rooms of the basement that it runs through, so shouldn't need to be insulated. How do I justify adding or not adding the pipe insulation to the piping?
Rich is offline   Reply With Quote
Old 02-27-2013, 06:57 AM   #2
Rewards Points: 13,472
Not needed but if it makes you feel better go for it. Not going to do any harm.
Tags
pex , pipe insulation , plastic tubing , uponor
Branching a bathroom supply line from 1/2" pipe ppeetteerr Plumbing 1 07-22-2012 02:46 PM
Water supply line blackhemi Plumbing 4 04-09-2011 08:18 PM
Gray PCV for water supply line - is this OK? Jim S. Plumbing 13 08-09-2010 09:20 AM
Water supply line replacement bamaknox Plumbing 2 01-08-2009 08:51 AM
hot pilot light supply line dlkk HVAC 1 02-24-2006 05:45 PM
