Pex Stub Out? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-19-2012, 05:14 PM   #1
Rewards Points: 101
pex stub out?
getting ready to start on my inlet plumbing on a house that I have removed all the original plumbing. I will be (my plan at least) starting my pex right off or very near the meter. I have not worked with pex before and have a couple of questions. is it reasonable to run 3/4" to the areas of the home and then 1/2" to each fixture? what is recommended for the stubouts? I've seen a few option at the home store but am not sure what is best, I'm not sure if I like the idea of stubing with pex and using the 90" plastic elbow things I've seen or should I use the brass parts that screw the framing and then screw a copper stub into them (sorry I don't know the proper names). So, anyway can some of you that use pex often give a few tips to a noob? Thanks, 1
BTW, passed my electrical inspection. thanks for the help of the other threads. 1
1dumbquestion is offline   Reply With Quote
Old 01-19-2012, 06:22 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,030
Here is what I like
http://www.pexsupply.com/Viega-44227...-Elbow-w-Plate
Coastal South Carolina
Old 01-19-2012, 06:29 PM   #3
Rewards Points: 12,790
That's are also my favorite, cheapest and fastest. There are two others but they require soldering or a plate and plastic snap in retainers that are pain, I
I'll only use them for something like a pedistal sink so I can get the valves closer together.
Old 01-19-2012, 07:06 PM   #4
Rewards Points: 101
that looks good, does that have holes on all sides for universal mounting?
How about manifolds. I was planning on running 3/4" and using T's at each fixture to branch the 1/2" but it seems as I read about pex the norm is to use manifolds for less conections/fittings. can I run 3/4" to a wall near the bathroom and then put a manifold in the wall and run 1/2" from there to each fixture or does the manifold have to have access for future use? Thanks, 1
Old 01-19-2012, 08:19 PM   #5
A "Handy Husband"
rjniles's Avatar
There are a number of holes in the mounting plate to handle any mounting direction.
A true PEX manifold system is located in a central area and home runs are made to each device. The manifold has shutoff valve and needs to be accessible.
Or you can use mini-manifolds (with or without valves).
The Following User Says Thank You to rjniles For This Useful Post:
ben's plumbing (01-19-2012)
Old 01-19-2012, 11:15 PM   #6
Rewards Points: 582
yes pex manifolds work well ,as long as they are installed right....proper sizing..
Old 01-20-2012, 12:15 AM   #7
Rewards Points: 101
Ok, went to my local home store. The stub outs they have don't have the plates so I may have to use a clamp of some sort. I think the manifold I was thinking of was the mini version, can I put this in a wall that will be drywalled?
My house is quite small with 1 bathroom, the stub outs for the bathroom and kitchen are all within 15 ft of each other along a wall (back to back). I'd like to run 3/4 to that wall and then run mini manifolds for cold and hot. Does this sound ok? Thanks,1
Old 01-20-2012, 05:12 AM   #8
A "Handy Husband"
rjniles's Avatar
If your house has a basement or a crawl space, I would install mini manifolds with valves under the house. This gives you the flexibility of cutting off a fixture while having everything else working. If you are on a slab and plumbing thru the attic, I would install the mini manifold there.
Drain line stub? oldhouseguy Plumbing 3 12-07-2011 06:34 PM
Gas Dryer stub out size in black pipe? ArtBraendel Plumbing 5 04-10-2011 08:23 PM
concrete stub wall daltinator Building & Construction 2 03-29-2011 09:58 PM
confused on to stub out plumbing bkeech Plumbing 1 02-28-2009 11:16 AM
bent the stub out redneckgeek Plumbing 3 01-07-2008 10:10 AM
