Pex Shower Rough In Valve, What Goes To The Shower Section? - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-11-2008, 04:43 PM   #16
Send a message via AIM to Marlin
Doing pex I always rough the entire shower body in copper and transition a couple feet away from the shower body. 10ft of half inch copper and a few fittings really isn't that expensive.
Marlin is offline   Reply With Quote
Old 06-19-2009, 11:08 PM   #17
valve body
Have you guys ever used a 1/2'' male to 1/2'' compression fitting . The 1/2'' male pipe fitting would screw into the valve body and a 1/2 copper pipe would slide into the other end and tightened in place. If the tear drop fitting on the shower end or spout end is off a bit you could loosen the nut on the compression side, turn the copper pipe then snug it up again. Saves soldering once everything is in place. What do you think. Doug
drumstick is offline   Reply With Quote
Old 06-19-2009, 11:30 PM   #18
GC/Master Plumber/Mech
Rewards Points: 560
Depending on the shower valve you can use a female or male pex adapter off the valve into copper then to a shower ear pex and secure it to a 2x4 then the spout. Just use copper everyone is right the difference in ID between the pex and copper will make the shower head drip.
Adapters
Drop ear
Old 06-20-2009, 12:27 AM   #19
valve body
Say plumber 101 have you used the brass compression fittings much for bathroom work or for joining two pipes together or quick repair. If so how tight do you tighten the nut to the sleeve so as not to overdue it yet not have it leak.I was told to snug it up hand tight and then half a turn with a wrench. Thanks.Drumstick
Old 06-20-2009, 05:45 PM   #20
Rewards Points: 560
Since shark bites I havn't used compression but you are on the money snug and about 1/4 to 1/2 more then check for leaks.
If I can't us a SB I'll sweat a fitting in
Old 06-20-2009, 10:18 PM   #21
Licensed Master Plumber
mstplumber's Avatar
Rewards Points: 150
Why use copper with Sharkbites?
Hey Drumstick,
I absolutely agree that you should use copper for the spout, but if you are going to use Sharkbites for the shower riser why not just use PEX? It will be lots easier and as long as you secure the Drop Eared Ell at the top it will be fine.
Mstplumber
Check out my goofy video for my new toilet repair book.
mstplumber is offline   Reply With Quote
Old 06-21-2009, 12:34 AM   #22
Thumbs up
copper and pex
Thanks for the help guys. I think I'II use pex on the hot and cold risers with 90 degree pex fitting, but stick with copper for spout and shower head.
Old 06-21-2009, 12:34 AM   #23
Old 08-09-2009, 07:37 PM   #24
Delta has pex fittings
This is too late for the original poster, of course, but for future researchers--I'm plumbing showers in my house right now, using pex. I went to a local plumbing supply house to get some shower valves and found that Delta makes valves with pex fittings on the hot and cold inputs. As far as the to showerhead and bath connections, you still have to get female to pex screw on adapters. Use four wraps of teflon and crank them down good. I think Zurn also makes some basic shower valves with pex fittings.
timistheword is offline   Reply With Quote
Shower Valve Destroyer ? Help! doneitnow Plumbing 2 05-05-2008 11:15 PM
Can't reinstall shower valve properly ptoneil Plumbing 3 04-10-2008 11:05 PM
How to change the shower valve? amdspitfire Plumbing 17 04-06-2008 10:05 PM
shower rough in frusteration! Lmiller Plumbing 5 03-13-2008 01:24 PM
aging symmons temptrol shower valve v240969 Plumbing 1 01-01-2008 06:24 PM
