Pex Quick Connect Fittings - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-22-2013, 09:10 AM   #1
pex quick connect fittings
does anyone know the pros/cons of the plastic vs the brass quick connect fittings, or any advantages of one over the other?
hit440 is offline   Reply With Quote
Old 02-22-2013, 09:42 AM   #2
Rewards Points: 340
there was a problem with some of the brass fittings 2 years ago .google class action lawsuits, I don't remember the particulars
of why or what brand . I always use the poly fittings .to use the similar materials seems safer to me
Call Zurn customer service they have an answer for you
kt82 is offline   Reply With Quote
Old 02-22-2013, 10:33 AM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 776
Only time I use any quick connect fittings is for temp. work. They're are too expensive and too new of a product.
How to wire a 30A 250v plug and connect it to a well pump control box diyorgobroke Electrical 3 05-21-2012 04:08 PM
how to connect bath fan exhaust pipe fittings amakarevic HVAC 1 04-03-2012 01:13 PM
Combine 7' garage doors into one 16+ ft door - connect brick lintels Irestone Concrete, Stone & Masonry 12 03-22-2012 03:51 PM
Apartment- Connect portable washer straight to sink drain + double quick connect? DrDreams Plumbing 1 03-14-2012 08:30 AM
Copper to Pex and Using "Gator Bite" Fittings? jdm001 Plumbing 5 12-21-2011 10:23 AM
