Pex And Pressure Treated Lumber - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-23-2013, 09:30 PM   #1
Pex and pressure treated lumber
I built the wall that houses my water lines with pressure treated lumber and am wondering if the pex and PT lumber will react to each other and cause problems down the line, can anybody help?
darrellkansas is offline   Reply With Quote
Old 04-23-2013, 09:55 PM   #2
www.inspectorzo.com
Send a message via Skype™ to InspectorZo
Talking
Good Question Darrel,
I have no specific experience with the two products together but am pretty sure there is no real problem. If you're concerned, you can always wrap some 3M tape over the polyethylene pipe where it comes in contact with your lumber. Also note that the chemical treatment applied to PT lumber is proprietary and so each treatment facility has a different formula.
Sorry I couldn't be more helpful.
Good luck,
InspectorZo
InspectorZo is offline   Reply With Quote
Old 04-23-2013, 10:06 PM   #3
Rewards Points: 13,300
Not going to be a probum, just wondering why you would build a wall using pressure treated lumber.
Sure hope this in not inside a home.
