#1 |
PEX Press tool?
Hi;
I am considering doing some work in my home using PEX tubing instead of copper. I need to consider the cost of the tools I need for PEX, since I already have all the "tools" I need for copper, and am not planning to do any major renovations, with either PEX or copper. If I use the Standard Crimp Ring system, is the crimp ring tool the only one, besides the cutter, that I will need? I do understand that I may need crimp tools for more than one size, unless the specific tool I purchase has two or more dies. I have looked at some on one web site, and it does appear that, like coaxial connector crimp tools, they usually have two different crimp "dies". I see another tool referred to as a "Press" tool. Am I correct in thinking that the press type fitting is a different animal that I will not be using if I use the Standard Crimp Ring system? Thanks for your comments/suggestions FW
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by KE2KB; 05-08-2009 at 06:11 PM. |
#2 |
D-I-Yer
PEX Press tool?
I was able to rent the proper crimp ring tool at the Home Depot. It was about $12 for 4 hours and can get a lot of fittings crimped if you do some preplanning. By using the "pro" rings, the ones with the collar on them, they stay in place easier making crimping go faster. I did the entire plumbing job "loose", then rented the crimper and went to town. The actual crimping took about 30 minutes.
I did buy a go/nogo gauge off ebay for $4 to make sur, then did my pressure test and am in use now. |
#3 | |
PEX Press tool?Quote:
I'll have to remember to buy the "go- no go" gauge. It could be a real time saver. I may also check Ebay for a crimping tool. FW
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#4 |
D-I-Yer
PEX Press tool?
I ended up buying the 1/2 in PEX tool for doing a renovation, nearly a complete re-plumbing on the pressure side. On eBay, the pex tool was about $75 with shipping. There are PEX tools that fit multiple sizes, but they wanted $120+ at the time, and it was not that important to me.
#5 |
D-I-Yer
PEX Press tool?
take a look here:
http://cgi.ebay.com/PEXcaliber-Multi...3A1%7C294%3A50 or here: http://cgi.ebay.com/PEX-Crimp-Tool-K...3A1%7C294%3A50 |
#6 |
PEX Press tool?
I just got one on ebay with a cutter for $33 shipped ( with a cutter) it is high quality and works great. If you near Wayne, NJ your welcome to borrow mine. But for $30 and change, might as well buy your own
http://cgi.ebay.com/ws/eBayISAPI.dll...lenotsupported |
| Display Modes | |
| Fein's Multimaster Tool...don't let the price scare you! | CrossWorks | Tools | 13 | 04-18-2009 07:39 PM |
| Drywall Inside Corner Tool? | helpless handyman | Drywall & Plaster | 24 | 02-19-2009 07:02 PM |
| Tool conglomerations, who owns who ? | iMisspell | Tools | 19 | 01-27-2009 01:41 PM |
| Tub Drain Removal Tool | rjordan392 | Plumbing | 6 | 07-08-2008 12:39 PM |
