Pex Plumbing Questions - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-18-2012, 10:32 PM   #1
I am going to try and tackle some plumbing troubles at home. I want to learn how to use pex. Most of the pipes in my house are galvanized so I think I can screw the pex adapters into the galv pipes and not have to solder. I don't trust myself soldering. Is there any how to guide about pex? What is the best, most versitile tool to buy?
Thanks,
Bill
pinbill is offline   Reply With Quote
Old 03-19-2012, 02:48 AM   #2
Homerepairguy's Avatar
Rewards Points: 990
Aren't you replacing the galvanized pipes with PEX?
HRG
Homerepairguy is offline   Reply With Quote
Old 03-19-2012, 09:07 AM   #3
Rewards Points: 20
Galvanized pipe does not require soldering. If you are replacing galvanized, depending on the age of the pipe you may have a hard time getting it apart. If you are adding new runs, there are fittings that screw into galvanized and adapt to PEX. Be sure to use thread sealant on all threded fittings.
daveb1 is offline   Reply With Quote
Old 03-19-2012, 12:40 PM   #4
Thanks I was just planning on doing the same project.
dstorjoh is offline   Reply With Quote
How to find plumbing distributors for plumbing invention? Timster Plumbing 14 03-14-2014 09:55 AM
Help How to Wire Bathroom "Fan Heater Light Night-light" unit, and questions Tryvidy Electrical 9 06-18-2012 03:37 PM
What is the standard method of water pressure test for shower plumbing please? Andy21 Plumbing 10 10-28-2011 05:06 AM
Plumbing questions Cjbeattie Plumbing 3 05-19-2011 05:41 PM
