Pex Plumbing Question... - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-15-2007, 05:36 PM   #1
I currently have the 1/2" red & blue REHAU pex lines coming from the manifold servicing all of the areas of my house. I now want to install pex to a new bathroom downstairs and can't find the same brand in the area. Can I use another 1/2 pex brand (and be safe)? Also, can I tap into an existing pex line (use a T)?
Thanks in advance for any help.
Scott
scsimmons is offline   Reply With Quote
Old 09-16-2007, 08:24 PM   #2
I believe the dimensions are the same for all pex pipe. I would opt to come from the manifold if possible but this may not be practical. Depending on circumstances a 1/2 inch supply may not prevent temp. and pressure fluctuations but sometimes you gotta work with what you got.
scrapiron is offline   Reply With Quote
Old 09-17-2007, 11:18 PM   #3
Journeyman Plumber
Ron The Plumber's Avatar
Pex is interchangeable between brands, no problem. yes use a tee.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 09-18-2007, 07:40 PM   #4
Thanks for the response!
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
Code Question: Electrical and plumbing ELurie Electrical 2 08-22-2007 09:55 PM
plumbing question dcden Plumbing 3 08-06-2006 02:49 PM
plumbing stack question vinman Plumbing 2 08-03-2006 07:02 PM
new plumbing in kitchen What have I done Plumbing 1 07-29-2006 12:14 PM
