PEX Piping Vs. CPVC - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-17-2008, 08:40 PM   #1
PEX piping vs. CPVC
I did some handywork in a mobile home. The owners of the park wanted the old copper replaced with PEX. Anyhow, during the winter, the heating oil ran out and the pipes froze...I was ready to have to tear out the old pipe and replace them...to my surprise, the pex did not split anywhere.
Does anyone find pex superior?
Also, are there any communities that allow pex in permanent residences?
Are ther any drawbacks from PEX?
-thanks
I_think_I_conduit is offline   Reply With Quote
Old 04-17-2008, 08:53 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Pex is a good product, as you have just found out, we use it widely here, so far there are no bad reports on it where I'm at. CPVC is not a great products.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 04-20-2008, 09:16 AM   #3
I put pex through out my house 2 years ago love the stuff I even used the quick connect fitting and last year when the furnece broke in the middle of winter no doubt not one pipe or fitting cracked or leaked.I have also read that some places do not allow the pex or the fittings due to it not being time tested yet so would check your local codes before putting it in
clasact is offline   Reply With Quote
Old 04-20-2008, 09:42 PM   #4
Registered User
Termite's Avatar
Pex will expand without breaking if the water inside it freezes. That is definately a plus. It has its drawbacks, but in my opinion the positives outweigh the negatives. I rarely see a house plumbed in copper anymore.
Old 04-22-2008, 07:54 PM   #5
Knucklez's Avatar
Rewards Points: 930
i like copper for simple DIY projects. because a 90deg. turn is 66 cents in copper and like 5$ in pex. plus the tool for crimping is $200 (though you can rent it).
however.. if i were plumbing a house from the beginning i would definately use PEX because it looks great and is really quick to install. the distrobution with PEX is just like with electrical which is cool.
Knucklez
Knucklez is offline   Reply With Quote
burying CPVC under concrete amakarevic Plumbing 17 03-25-2008 09:45 AM
How would I fix/re-do my sink's drain <leaking> piping? joeyboy Plumbing 17 12-18-2007 06:23 PM
PVC piping allowed in NY? honeydew Plumbing 6 11-21-2007 07:57 AM
How to connect non-threaded 1/2 inch CPVC to a compression shut-off valve andy Plumbing 6 12-12-2006 10:02 PM
