Old 06-18-2010, 07:35 AM   #1
pex piping
how do you size pex piping, when installed in a traditional method like a copper system which incorporates tees for branch connections?
..some manufacturers reference the Uniorm Plumbing code or national plumbing codes but some do not make a reference....they recommend the Home Run method.
wallport is offline   Reply With Quote
Old 06-18-2010, 07:55 AM   #2
pex piping
Its sized pretty much the same way copper is sized, based on fixture unit counts and how many fixtures each leg of the system serves. Also taken into account are distances, available pressures and elevations. The only difference between copper and pex, is the friction loss co-effiecient when determining the pressure available for friction loss.
The Engineer is offline   Reply With Quote
Old 06-18-2010, 09:15 AM   #3
pex piping
The reason copper has size limits, is because water flowing through it at high velocities wear it out and it can be very loud.
For cold water, copper pipe shouldn't have a flow of greater than 8 feet per minute and for hot water 5 feet per minute.
How that affects PEX I don't know I think it would have a different set of rules.
Piedmont is offline   Reply With Quote
Old 06-18-2010, 09:28 AM   #4
Civil Engineer
pex piping
Piedmont, you need to check your units. The flow you quote would be in feet per second, not feet per minute. And copper can certainly handle more than 8 feet per second, its simply that at higher velocities you get greater pressure loss in the pipe, and hence lower pressure at the fixture. Standard tables for copper pipe typically show losses up to 25 feet per second for applications where pressure loss is not significant.
exterior piping for Nat gas rcassidy Plumbing 3 03-16-2010 07:32 AM
Piping Layout for New Bathroom structman Plumbing 2 02-23-2010 06:24 PM
Copper Or Iron Piping? beatboy77 Kitchen & Bath Remodeling 2 01-03-2009 01:36 PM
How would I fix/re-do my sink's drain <leaking> piping? joeyboy Plumbing 17 12-18-2007 06:23 PM
PVC piping allowed in NY? honeydew Plumbing 6 11-21-2007 07:57 AM
