PEX Pipe Water Softener Install - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-22-2013, 02:42 PM   #1
I am getting ready to install a Fleck 5600 series water softener. My main water line comes into the garage has a shut off valve and then goes straight up into the attic through 1" or 1 1/4" PEX pipe. My sprinkler and outside faucets are on their own line.
Question #1: Should I get a 3/4" or 1" bypass valve with the softener?
Question #2: Should I put a sediment filter in before going into the softener?
Question #3: What type of PEX fittings should I use? I like the Shark Bite are they reliable?
Question #4: I have a drain right outside the garage wall in the sidewalk of my backyard, can I use this for the softener drain?
Thanks,
Chris
Chris Humiston is offline   Reply With Quote
Old 04-22-2013, 10:38 PM   #2
Rewards Points: 13,274
The by pass should be built into the softner.[/COLOR][/COLOR]
I would.
There fine but very expencive compaired to the crimp on.
Sure
Thanks,
Chris
Read between the lines.
Old 04-23-2013, 12:59 AM   #3
Thanks for the answers.
I have verified my incoming main line is 1 1/4" PEX and the softener I'm buying offers a 3/4" or 1" bypass valve. So I'm guessing the least amount of reduction in pipe size the better correct?
Old 04-23-2013, 09:55 AM   #4
Correct.
Installing water softener: reducing pipe size. handyman92865 Plumbing 26 01-24-2013 03:06 PM
Water Softener Drainage Problem hodge23 Plumbing 3 09-26-2011 05:40 PM
Culligan water softener not working (pics) Perm Plumbing 46 09-14-2011 01:29 AM
Water Softener Resin Bed Clogging with Sediment? batman71 Plumbing 2 02-23-2011 12:38 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
