Pex Pipe/tube - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-31-2012, 02:11 PM   #1
pex pipe/tube
Does anyone know a way to relax the coils in the pipe.
jenk is offline   Reply With Quote
Old 03-31-2012, 03:35 PM   #2
Civil Engineer
Rewards Points: 4,700
The coils can be relaxed by warming them up and stretching the coil out, say in the backyard. Personally I do not bother to straighten them out, I just run out enough length for what I am doing and pull it straight, but if you must straighten them for personal reasons then as I say they will straighten much better when warm. Do not leave PEX in the sun for more than a few hours, sunlight damages the plastic. You can run warm water through the coil, that should work.
Old 03-31-2012, 04:36 PM   #3
Homerepairguy's Avatar
Rewards Points: 998
+1.
I was concerned about the coils in the 3/4" PEX tubing when planning my installation (never installed PEX before). When actually pulling the PEX through the attic, it was a piece of cake with a friend feeding the PEX from the source end directly from the coiled PEX. Just be sure the "feeder" person "rolls" the PEX tubing off the coil like a conventional fishing reel, rather than pull the PEX tubing off the coil like a spinning reel.
HRG
Homerepairguy is offline   Reply With Quote
