PEX Pipe To Tub Faucet - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-21-2011, 11:12 PM   #1
Rewards Points: 18
PEX pipe to tub spout
Hi,
I have PEX pipe out of the wall going to the tub spout. Since it flexes I don't have a very tight fit against the wall (not like I would with copper anyways).
First question is is this even up to code (I am in BC). Second is, how can I fit it in a bit tighter.
Thx,
Michel
MichelDionne is offline   Reply With Quote
Old 02-21-2011, 11:23 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 678
best to change it to copper. Much more rigid. But, you know this now
Old 02-21-2011, 11:34 PM   #3
Doing it myself
Alan's Avatar
Rewards Points: 2,086
using pex for a tub spout is no good, especially if you are installing a tub/shower.
The pex fitting at the spout creates a reduction in flow, and this will cause your showerhead to drip. Use copper or brass or even galvanized would be better than pex.
Journeyman Plumber
Old 02-21-2011, 11:44 PM   #4
Rewards Points: 18
Yea I'm just dealing with the crap from the previous homeowner.
I'm also wanting to get permits after the fact. Anyone know if this is conform to BC building codes? (if it is it shouldn't be... but this is just my opinion)
Old 02-22-2011, 12:41 AM   #5
Rewards Points: 212
you said it brother
bluebird5 is offline   Reply With Quote
Old 02-22-2011, 03:19 PM   #6
I don't believe that it's against BC code per se, just against common sense. If the spout has a set screw, the pex would puncture.
As for getting it to fit tighter, the installation instructions will tell you the depth/length of pipe (ie - min 1 1/2" to max 2 7/8") from the wall. So when you replace the pex with copper/brass make sure that the pipe is the right length and you'll be good to go.
VIPlumber is offline   Reply With Quote
Possible to join PVC drain pipe to old iron pipe? darsunt Plumbing 7 03-01-2014 01:53 PM
Selecting a New Kitchen Faucet klumbsy Kitchen & Bath Remodeling 4 02-25-2011 08:29 AM
AC Coil drain pipe questions fritzycat1 HVAC 14 11-12-2010 03:51 PM
Bernoulli's Principle, increase 3/4" pipe to 1-1/4" or 1-1/2" copper ChrisDIY Plumbing 14 09-18-2010 09:49 PM
Rattling garden faucet supply pipe OneTripper Plumbing 2 06-29-2009 07:58 PM
