PEX Pipe To Sink Threaded Connection - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-04-2011, 03:45 PM   #1
PEX pipe to sink threaded connection
I had a pex line with clamp ring come off of a fitting under the sink. The fitting appears to be a PEX fitting (brass) with a plastic nut / sink thread. I have been unable to find these components and confirm they are actually a PEX fitting. Is anyone familiar?
pielady is offline   Reply With Quote
Old 01-04-2011, 04:27 PM   #2
Homerepairguy's Avatar
Rewards Points: 998
Maybe posting a picture of what you have will help the pro's figure out an answer.
BTW, when the pex line came off, did it flood your home? If so, about how long was it shooting water before you discovered the problem?
HRG
Homerepairguy is offline   Reply With Quote
Old 01-04-2011, 06:46 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 682
is this it? http://www.pexsupply.com/HydroPEX-H190500-Plastic-Faucet-Swivel-Adapter-1-2-PEX-x-1-2-NPSM-4498000-p
removing Cast Iron drain pipe jimmyfloyd Plumbing 1 01-04-2011 03:47 PM
Installing bathroom sink - drains off slightly less than pipe diameter lazzlazz Plumbing 17 05-21-2010 05:12 PM
disposal sink flange without the disposal? wolfv Plumbing 2 04-29-2010 06:24 AM
reducing pipe size for sink drain bluebee1314 Plumbing 5 12-02-2007 12:53 PM
Drain connection for basement utility sink chickenboo Plumbing 5 09-11-2006 02:30 PM
