Pex Pipe In The Attic? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-06-2009, 01:03 PM   #1
wolfdog
Question
Pex pipe in the attic?
Hey guys, just found this site, and it looks great. I am building a new home, and am using PEX pipe for the water. I am running the supply UG, obviously, but am planning to run the sub-feeds overhead. What is the best way to insulate the pipe in the attic? Our temps range from about 120* down to 0" in the attic, depending on the time of year.
Or should I consider running it all UG?
krazni is offline   Reply With Quote
Old 01-06-2009, 01:13 PM   #2
Rewards Points: 562
More info needed. What kind of basement?or crawl?or slab?
One note--water wont run too good at 0* F. for ANY amount of time.
4just1don is offline   Reply With Quote
Old 01-06-2009, 01:20 PM   #3
wolfdog
no crawl space -- slab on grade.
Old 01-06-2009, 02:50 PM   #4
Registered User
Termite's Avatar
Avoid running the pipes in the attic at all costs. Insulation helps, but generally won't do enough in an attic if it is 3 degrees outside. I'd suggest going underground wherever possible.
Old 01-06-2009, 07:23 PM   #5
wolfdog
So a couple quick questions:
1. do I need to sleeve the pex in the ground, or just sand it? And how deep?
2. When I turn up, I presume I need to sleeve it through the slab; is there a better way than sleeving it in a PVC elbow help keep the radius as it turns up?
Old 01-06-2009, 11:00 PM   #6
Registered User
Termite's Avatar
You can direct bury most PEX, but check with your local codes department to make sure they don't have any special/specific requirements. Yes, use pipe insulation pieces to isolate it where it penetrates the slab.
Old 01-06-2009, 11:40 PM   #7
I love pex pipe,they make fittings for just about every application. You can mix copper and pex water supply lines
and save yourself alot of time plumbing. I use Vangaurd pipeing systems, LINK REMOVED. Check the site
Frederick j Ward is offline   Reply With Quote
Old 01-07-2009, 12:24 AM   #8
Avoid connections if they are buried. You want to go for complete runs. The crimp fittings are not rated for burial.
My idea of a perfect day: No where to go and all day to get there.
Marvin Gardens is offline   Reply With Quote
Old 01-10-2009, 09:44 AM   #9
I stake my pex coming up through slabs, i used to use rebar as the stakes but i found the smooth surface of EMT much better so no abrasion takes place, just hammer in the stake where you want the water lines to come up sleeve the pipe and duct tape, wham bam!
zosoplumber is offline   Reply With Quote
Raccoons in the attic electricpete Pest Control 17 05-12-2011 05:02 AM
Septic/sewer pipe replacement Mendocino Plumbing 4 11-21-2008 06:40 PM
Furnace Venting Requirments jamiedolan HVAC 9 11-18-2008 06:40 PM
Running a pipe between basement & attic Piedmont Electrical 4 06-12-2008 11:35 PM
Need to support 15th of ABS pipe irishtimes101 Plumbing 3 09-01-2006 12:09 PM
