Old 02-06-2007, 06:08 AM   #1
pex pipe
I think I owe a big thanks to Ron the Plumber here for all he has said about pex pipe.I just replaced all me water lines with it and the new quick conenct conectors what a breeze ,if it wernt for what I had read on here I would have used copper or pvc and been at it all day and then some but this only took a few hours .Who ever invented this stuff should win some kind of home repair award
clasact is offline   Reply With Quote
Old 02-06-2007, 08:23 AM   #2
Journeyman Plumber
Ron The Plumber's Avatar
pex pipe
Glad it went well for you pex is the way to go.
Fix it right the first time, so you won't have to fix it a 2nd time.
Ron The Plumber is offline   Reply With Quote
Old 02-06-2007, 08:54 AM   #3
pex pipe
your so right cant see why anyone would use anything else.Makes me think about going into the plumbing biz just kidding Thanks
Old 02-06-2007, 09:05 AM   #4
Long-Time DIYer
Mike Swearingen's Avatar
pex pipe
Unless specified otherwise by the homeowner, PEX is all that the pro plumbers in this area have been installing for years.
I went copper when I built my home back in '77, but I would definitely go with PEX today instead.
Mike
Mike Swearingen is offline   Reply With Quote
Old 02-06-2007, 06:33 PM   #5
pex pipe
Mike
Yeah , yet they still charge the same as if they were installing copper, I had a guy quote me $11,000 to redo my house with pex. Ill be doing it myself thank you.So whats the link to rons post? i have read alot but im sure the info comming stright from a pro would be alot better than the technical litterature Ive been thumbing through.
Offalot is offline   Reply With Quote
Old 02-06-2007, 06:48 PM   #6
pex pipe
just look back on some of the past postings and you will find his very sound advice. Oh and like I mentioned befor those quick conect conector are unreal you will love them
Old 02-07-2007, 12:57 PM   #7
pex pipe
faster than copper....
redline is offline   Reply With Quote
Basement Rough In Advice Needed mikemille Plumbing 5 02-18-2007 10:55 AM
Use of coupling fitting on gas pipe Fred Plumbing 3 01-28-2007 07:13 AM
Replacement pipe for hot water heat? Tmb9862 HVAC 18 01-12-2007 04:31 PM
Need to support 15th of ABS pipe irishtimes101 Plumbing 3 09-01-2006 12:09 PM
Vent Pipe Leak romeguy1 Plumbing 9 12-11-2005 01:08 AM
