To PEX Or Not - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-11-2012, 10:36 AM   #1
To PEX or Not
Currently my home is plumbed with CPVC. Im going to be adding some fixtures in the basement.
PEX seems like I will have less joints and quicker. My concern is converting from CPVC to PEX. I see a lot of information about the sharkbite but would rather use a solvent weld like http://www.siouxchief.com/Supply/Fit...-Adapter.7X8VK to convert. Unfortunately I cannot find these locally. Should I just go with the sharkbite or get a solvent weld converter or just stick with cpvc?
THANKS
casnj is offline   Reply With Quote
Old 02-11-2012, 12:03 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 796
If this were my project I would remove all the CPVC I could cuz I can't stand the stuff. But you should find the solvent fittings if you can. Try plumbing supply houses or buy them online. I'm not a fan of sharkbites either but thats my opinion. I've always found a way around them
The Following 2 Users Say Thank You to TheEplumber For This Useful Post:
ben's plumbing (02-11-2012), plummen (02-11-2012)
Old 02-11-2012, 03:11 PM   #3
Rewards Points: 582
for sure get rid of all cpvc......pex is better and will take half the time to replace::
