PEX Line For Air? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-02-2007, 06:33 AM   #1
PEX line for Air?
Has anyone Used Pex line as Air supply Line?? I'd like to run a line in from the Garage to the Basement for Airbushing.
mdlbldrmatt135 is offline   Reply With Quote
Old 02-02-2007, 07:46 AM   #2
I realize that airbrushing uses lower pressures than many other compressor projects, but, I would not use ANY plastic pipe for air. Should it fail, there will be very sharp projectiles flying all over the place. I have seen the "curly Q" tailpieces used for attaching tools at the end of the line, break and throw pieces. My choice, if I wanted to run a flexible line, would be to use regular compressor hose.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
ac suction line placement? nimbenja HVAC 8 10-28-2009 05:43 AM
Condensate Line schott HVAC 17 06-02-2008 03:16 PM
how to run fridge water line under kitchen floor? travishume Plumbing 23 09-26-2006 07:51 AM
Relocating water supply line from well Mikedks Plumbing 6 09-22-2006 01:41 PM
Installing exterior faucet to washer line? skellies Plumbing 3 06-18-2006 08:19 PM
