pex or kitec
Hope to start construction on our house this spring. What are the po's and con's of these two pipe systems compare to copper.
Personally I like cpvc for hot and cold runs.
oddjob---me too
DM |
I like PEX and prefer the home run/manifold system, the ease of installation, and dog gone it...it's just plain fun!
i like pex it's a great product easy to use although the crimp tool is around a $100 to buy very worth it, very flexible, make sure to purchase stainless steel crimp rings. pex can be purchased in 100ft rolls at home depot or lowes it also comes in red for hot and blue for cold. it also comes in 20ft sticks from a contractor supply house. one more thing about pex that a plumber told me he put a 16d nail througn the center of a 3/4 inch within 5 min it sealed itself, as well as the cold it will expand 5 times it's diameter. hope this helps.
I like pex because it is more freeze resistant than copper, PVC or galvanized. There have been pex that was frozen solid for a week in eastern Oregon and when it was thawed out it worked fine. Can't do that with copper or PVC. Also it has better flow as you can get by with less fittings. The down side is that you can't get high sniffing pex. :laughing: |
one thing i've not seen mentioned yet is price. in today's economy, prices for everything doubled and tripled every week, i suppose if you can afford to buy pex, ok. but it's cost prohibitive to some. i've found cpvc lying along side the road many times. falls off trucks around here. can't say that about rolls of pex though.....PLUS----> $100 tool + $? for fittings vs. $3 primer and glue to install. no needing major math skills there to see why we chose cpvc. would i use pex? heck yeah! when i can get tool, fittings, and enough to do the job at an auction......
DM |
Many places will rent the tool for $10 a day. My local plumbing shop loans the tool out if you buy the pex from them. If you don't like the tool you can use sharkbites but they are expensive.
Yes it is more expensive but it is just so much nicer to work with. 1/2" is about 41 cents a foot if purchased in 300 foot rolls which is slightly more expensive than CPVC. The advantage is that with 1/2" you can bend it around corners and don't need as many fittings. Overall I would say that pex is comparable to CPVC. |
| All times are GMT -4. The time now is 01:35 AM. |
