PEX Issue - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-09-2009, 06:27 PM   #1
DAGWI
PEX Issue
I'm going to finish the lower level of our townhouse. The house is plumbed with AquaPex tubing and fittings. When I get to roughing in the new bathroom can I cut into the existing system using PEX tubing and crimp fittings that I can get at Menards or Home Depot?
DAGullickson is offline   Reply With Quote
Old 10-10-2009, 01:19 AM   #2
yes you can but just don't cut into the other pex lines if they are 1/2" because they not be able to supply everything. Usually cut in some tees off of the main line and feed the pex off of that.
fhrace is offline   Reply With Quote
Old 10-10-2009, 12:40 PM   #3
Civil Engineer
Rewards Points: 4,944
Aquapex is a Wirsbo (Uponor) product. Wirsbo fittings are not the same as fittings for other brands of PEX. My house is done entirely using Wirsbo tubing and fittings, however I cannot obtain Wirsbo fittings at Home Depot, I have always gone to my local plumbing supply shop. It is possible that other brands of fittings will work with Wirsbo tubing, as it may be that the tubing itself is standardized, but perhaps a plumber on this forum with specific knowledge of fittings and PEX can chime in.
I have the special Wirsbo expander tool for PEX, it works very well, but costs about $300. Other fittings use different tools, they may be less expensive, but I have no knowledge of how well other fittings work. You may want to check out the current lawsuit against Zurn for failure of their brass PEX fittings, I always use the plastic Wirsbo fittings.
Daniel Holzman is online now   Reply With Quote
Interlock Paver Issue cbadrik Landscaping & Lawn Care 2 07-27-2009 07:29 PM
HELP - with my breaker box. Interesting issue. LordX Electrical 75 02-23-2009 03:14 PM
Cable issue or wiring issue? Duchey Electrical 57 12-15-2008 01:34 PM
Fireplace framing/tile issue robdville Building & Construction 13 11-14-2008 07:14 AM
Unusual electrical issue LosLobo Electrical 7 11-10-2008 01:44 PM
