Pex And Hose Clamps - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-18-2013, 11:37 AM   #1
Rewards Points: 3,130
Pex and Hose Clamps
Okay, I know it's probably not to code, but my question relates to an RV so code isn't an issue.
I need to replace a valve on my water heater bypass. Rather than spending the money for a tool I'd only use once (and probably don't have the room to use), would there be a problem if I just use hose clamps? RVs are high maintenance anyway, so if I have to periodically check and retighten the clamps, that's not a problem. Or is there a pex crimp tool for confined spaces??
Old 01-18-2013, 11:49 AM   #2
Roofmaster
Rewards Points: 2,172
Use a shark bite coupling.
Old 01-18-2013, 11:54 AM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 360
Nope,... Hose clamps will Not seal a pex joint, no how, No way...
Bondo is online now   Reply With Quote
Old 01-18-2013, 02:40 PM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,034
Home depot sells a PEX pocket crimp tool that works with a pair of vise grips. About $25 a d is great for the cramped spaces in a RV.
Coastal South Carolina
Old 01-18-2013, 04:22 PM   #5
Great, thanks. That's probably cheaper than what Sharkbites would cost. Since the installed valves are apparently not too good, I'll probably just replace all three. A friend of mine had the same valve fail on his RV.
Old 01-19-2013, 01:59 AM   #6
Sharkbite 1/2 inch couplings are only $6 here in Montreal, so $18 for three. A lot easier than crimping in a confined space (just did a couple of dozen crimps, and my arms still hurt).
profcolli is offline   Reply With Quote
Old 01-19-2013, 06:28 AM   #7
Thanks. I've heard of Sharkbites but not ever checked them out.
