Pex Fittings Wont Fit - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-04-2011, 07:22 PM   #1
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 90
Pex fittings wont fit
I'm new to pex, so I'm probably doing something wrong. I bought some pex (shown in pic) and shark bite and dahl fittings and can't seem to put any of them on it.
The insert that goes inside the pipe does not fit, as the pipe's inner diameter seems too small. It is 1/2 pipe and 1/2 fittings. Do I need to use a heat gun to sofen it first? The pipe is actually very hard, I expected it to be more like medical tubing but a bit harder but this is actually like hard plastic that is flexible but very stiff. Is this the right type of pipe?
Old 02-04-2011, 07:33 PM   #2
that doesn't look like the pex you want. what does the whole printed label say? whats the astm number printed on it? that'll tell ya what it is
the_man is offline   Reply With Quote
Old 02-04-2011, 07:43 PM   #3
Wire Chewer
Rewards Points: 90
Says
"BOW Superpex Made with/Fabrique avec TempRite(R) PEX 1/2" CTS MR 1293 ASTM F876/F8// 690 kPa-82C /100 PSI" A lot more stuff on it such as fire rating.
Old 02-04-2011, 07:52 PM   #4
hmm... is that pipe black on the inside? never seen that before. it looks like the pex you want to use, 1/2" CTS means it will be 5/8" OD. Try trimming a couple inches then try the sharkbite again
Old 02-04-2011, 08:01 PM   #5
Wire Chewer
Rewards Points: 90
Yeah it is black inside, here's some more pics.
First pic is the end of the insert that is suppose to go inside, and the pipe, other is the fitting itself. I have not tried putting the 1/4 tube yet but I think that will be more trivial as it's a soft plastic.
Old 02-04-2011, 08:04 PM   #6
Seasoned DIYer
Rewards Points: 150
Is that one of those metal stiffened shape holding or oxygen barrier hydronic heating type? You should contact CASH ACME and ask them.
HVAC_NW is offline   Reply With Quote
Old 02-04-2011, 08:06 PM   #7
that pex looks a lot thicker than the stuff i've seen, not sure why. does the fitting fit over the pipe? if it does, i'd just go ahead and connect it without the stiffener.
Old 02-04-2011, 08:10 PM   #8
Wire Chewer
Rewards Points: 90
It looks like it would go in. The instuctions say I only need it for pex, and that for copper I don't use it, and this pex seems to be about as stiff as copper, so I was also wondering the same, if I can just leave it out.
The shark bite ones have the stiffener built in though. Am I better off to just shave the inside of the pipe a bit? I just don't want to do this in hacks, either.
Old 02-04-2011, 08:16 PM   #9
Seasoned DIYer
Rewards Points: 150
The shark bite ones have the stiffener built in though. Am I better off to just shave the inside a bit? I just don't want to do this in hacks, either.
You can pull the stiffener out, such as when you're using it with CPVC or copper. Should you in this case? I don't know. You should ask Cash Acme, or the pipe manufacturer.
Old 02-04-2011, 08:35 PM   #10
Rewards Points: 152
Have you cut the pipe yet?
I was working with some lengths we bought from HD and the rings wouldn't fit until I cut the end off the pipe. I guess the factory cuts squish the end a bit and make it egg-shaped.
burnt03 is offline   Reply With Quote
Old 02-04-2011, 09:01 PM   #11
Rewards Points: 276
I admit I don't know a lot about PEX tubing but what I've seen is always one solid plastic looking material through and through like this http://www.pexsupply.com/PEX-Tubing-223000 . They will typically sell it in red or blue and I think it is to color code- Red for Hot and Blue for Cold. What I bought and use was a solid White which I used for both hot and cold. Used both Shark Bite and PEX cripm ring fittings on it with no problems. I am not familiar with the tubing or the fitting you have pictured.
Jim F is offline   Reply With Quote
Old 02-04-2011, 09:01 PM   #12
Wire Chewer
Rewards Points: 90
I was playing with it and after a bit of brute force, I did manage to get it in (that's what she said!) Used needle nose plysers to expand it a bit, and just rolled the rough end of the plyers inside the tube a bit to scratch off any material sticking out. I think my cutter tool did what you described about the factory ends.
For the 1/4 connection, the instructions don't say, but it's just the thing of putting it through the screw ring, and then putting the little ring on the end, putting it in the fitting, and screwing it tightly with a wrench? I don't imagine that much pressure on a 1/4 fitting so I did not do the same strenght pull test as I did with the 1/2. So far so good.
Now for the moment of truth, I'm about to tap into the live water line. Is it normal that I'm more scared to do this, then the first time I opened my electrical panel? LOL Going to shut the water and drain pipes first, obviously. Here goes...
Oh, and another thing, is there a problem with having a pipe run over furnace ducts? It's the only way to get it to the other side unless I run it under but then I don't have a good way to fasten it. A PDF I downloaded on this product says to keep within 12 inches of heat sources, but would a duct be classified as such? It's not like it's enough heat to melt anything. I can put my hand on it and not get burnt, though it is a bit uncomfortably hot.
Old 02-04-2011, 09:57 PM   #13
Civil Engineer
Rewards Points: 4,702
That appears to be hydronic heating PEX with an aluminum insert as an oxygen barrier. Are you using it for potable water or heating? The sharkbites I used on my PEX were specifically for potable water PEX, I do not think they were intended for use with hydronic PEX, but you should be able to check through the manufacturer.
Daniel Holzman is online now   Reply With Quote
Old 02-04-2011, 10:12 PM   #14
Wire Chewer
Rewards Points: 90
Hmm does not really specify, I thought they were all the same system. I'm going to guess it's for potable water though, but I could be wrong.
I did manage to get it all done, the hot water pipe that goes to the shower which I T'ed at seems to have magical powers of being able to supply unlimited water, even when the main is off. Glad this is an unfinished basement. That was quite the mess but managed. There was a small leak on one of the fittings but it may have been from the excess water, I wiped it and I'll have to watch it. Going to let everything be for a while and keep an eye on it for the next few weeks. I just hope I did it all right and it holds up. I do want to invest in the crimper tool next time I have a bigger project, and might even redo the joins I did, just for piece of mind but my testing seemed to proove the shark bites quite good. I could not pull it off.
Old 02-04-2011, 11:56 PM   #15
Red Squirrel said "I'm new to pex, so I'm probably doing something wrong. I bought some pex (shown in pic) and shark bite and dahl fittings and can't seem to put any of them on it. I was playing with it and after a bit of brute force, I did manage to get it in..."
Good work Red. Sometimes all it takes is a little patience and elbow grease. Or plumber's grease. I'd recommend trying to use the stiffener on pex.
the_man said "hmm... is that pipe black on the inside? never seen that before."
We've seen a lot of that pex out here, more so than the red & blue, and use it for our potable water installations. Ask for pex and that's what they bring you, unless you specify red & blue.
HVAC_NW said "Is that one of those metal stiffened shape holding or oxygen barrier hydronic heating type?"
The metal stiffened pex is called pex-al-pex and looks something like this
The thin aluminum band is quite visible when looking at the cut, and is a to cut.
VIPlumber is offline   Reply With Quote
New House + PEX + Plastic Fittings = ? GaryZ Plumbing 22 01-06-2011 08:47 AM
remove compound from brass fittings to unscrew fittings purpleheart Plumbing 3 05-08-2010 06:49 AM
Barbed fittings into 1-1/2 inch Black Poly MI-Roger Plumbing 3 04-16-2010 06:44 AM
Sharkbite brand PEX fittings at Home Depot rjniles Plumbing 1 03-16-2010 07:33 PM
iron pipe fittings farrington135 Plumbing 1 07-13-2007 08:16 PM
