Pex Fittings Brass Vs Plastic - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-01-2010, 10:49 PM   #1
Rewards Points: 153
Pex fittings brass vs plastic
I am on a well system, that seems to be rather corrosive to the existing copper.
I currently have my water out for analysis.
I am looking into replacing the corroded copper with pex tubing.
I see they have copper, brass and plastic fittings.
Any thoughts on using the plastic fittings?
It maybe a mute point, cause I need to use brass for the valves.
theedudenator is online now   Reply With Quote
Old 02-02-2010, 12:39 AM   #2
Do something
D'Brie's Avatar
We use Wirsbo at our shop. Plastic rings and both plastic and brass fittings. You can run Wirsbo, use plastic rings and whatever set up in the product line for your valves. It's good stuff.
D'Brie is offline   Reply With Quote
Old 02-02-2010, 06:21 AM   #3
Rewards Points: 85
I have had about 6 plastic fittings from one of the big box stores in my basement now for a water softener I installed about 8 months ago and no problems to date. The only thing I would suggest is make sure the pex is completely round, if not it will not seal within the fitting. Other than the minor shape problem I have been very happy and I'm looking forward to replacing some more of my piping in the near future with more pex.
mferguson0414 is offline   Reply With Quote
Old 02-02-2010, 08:11 AM   #4
I redid all my copper lines in my house with pex about 6 years ago and used the shark bit fittings mainly because I knew I would be moveing some of the lines as the renovation continued and it would be alot quicker then cutting and reclamping they worked so well I just reused them and left them on.To date I have had no problems with any of them the plastic or the brass.We had well water for the first 3.5 years with very heavy sediment.When I took the copper out it was 3/4 clogged.So far none of the fittings show any sign of clogging up.I do know that the plastic ones are made for valves I used them for shut offs to the washer but in your area they may not be up to code (some place still dont allow them).As stated though if you do use them make sure your cuts are square and the pex is well seated
clasact is offline   Reply With Quote
Old 02-02-2010, 11:35 PM   #5
Rewards Points: 153
I actually have the crimping tool for the copper rings.
And from what I have read I can use brass or plastic fittings (with the copper crimp ring)
I am still wondering if I should go brass or plastic.
This will start with 1" pipe from my well, feed to 3/4" and finally end at 1/2" by the fixtures.
Old 02-03-2010, 09:58 AM   #6
I would think that you would get less clogging and the cost would be less if you went with the plastic but I have not used the cripmer on either so I could not say how either one works better then the other maybe someone else has ....sorry
Plastic plywood, Plastic sheets, Plastic decking Spud Building & Construction 1 10-16-2009 05:43 AM
Plastic - using plastic to make your own replacement parts Hemingway General DIY Discussions 5 09-26-2009 08:49 AM
Joint compound on brass fittings for natural gas? larrycassidy Plumbing 5 07-13-2009 09:31 PM
PEX or copper to replace old pipe indoors? Ultrarunner2017 Plumbing 15 03-29-2009 11:44 AM
Brass Plated Fixtures rjordan392 Plumbing 5 06-19-2008 10:19 PM
