Pex Fittings - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-29-2010, 10:11 AM   #1
pex fittings
Is there such a thing as a 3/4 inch pex angle stop valve? If so where can I get it?
bkissell is offline   Reply With Quote
Old 06-30-2010, 09:32 AM   #2
Owner
LateralConcepts's Avatar
I don't recall ever seeing a 3/4" brass insert for PEX on an angle stop. I believe they only come in 1/2" brass barb x 3/8" OD compression. Which can be found anywhere. What will it be used for? If need be you could just use a 3/4 x 1/2 reducing coupling
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
Old 06-30-2010, 10:03 AM   #3
Doing it myself
Alan's Avatar
Rewards Points: 2,086
we have those fittings in our uponor pex variety.
3/4 pex x 3/4" male sweat.
Not sure why you want a 3/4" angle stop though....
Journeyman Plumber
remove compound from brass fittings to unscrew fittings purpleheart Plumbing 3 05-08-2010 07:49 AM
Barbed fittings into 1-1/2 inch Black Poly MI-Roger Plumbing 3 04-16-2010 07:44 AM
Sharkbite brand PEX fittings at Home Depot rjniles Plumbing 1 03-16-2010 08:33 PM
Propane lines in an RV...Flare Fittings K-mann Plumbing 3 09-18-2008 10:06 AM
iron pipe fittings farrington135 Plumbing 1 07-13-2007 09:16 PM
