Pex Double Up Crimps Rings - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-11-2013, 09:15 PM   #1
pex double up crimps rings
New to pex and not sure I trust it. Im running some 1/2 pex in basement(only in a few places where copper is to difficult to use). Is it possible to double up crimp rings on each fitting for extra security?? or is that over kill? I tried it and both fit. Any thoughts??
Stcrosby is offline   Reply With Quote
Old 03-11-2013, 09:25 PM   #2
copper
As long as you properly crimp your first ring you will be fine. Leave the crimp ring approxmately 1/4" back from the end of the pipe and make sure it's over the barbed portion of the fitting and crimp down. So to answer your question directly, yes two rings is overkill and not needed.
Gerb10 is offline   Reply With Quote
Old 03-11-2013, 09:30 PM   #3
Rewards Points: 616
well i have never heard of putting to bands on a bull just in case
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 03-11-2013, 09:54 PM   #4
Rewards Points: 6,652
Pex has been used for over 20 years with no problems. Follow manufacturer directions and you will be fine.
The Following User Says Thank You to gregzoll For This Useful Post:
TheEplumber (03-11-2013)
Old 03-12-2013, 09:03 PM   #5
thanks guys
Double switch wiring rockclimber Electrical 18 03-18-2012 11:13 PM
Changing A Double Switch to a single pole switch and a dimmer switch loydbrahn Electrical 0 11-09-2011 12:00 AM
Double Hung vs Single Hung CZSteve Remodeling 0 11-08-2010 08:29 AM
double pole breaker + outlets / x10 BlueBSH Electrical 0 09-09-2010 01:44 PM
How Does A Double Pole Circuit Breaker Trip? shadowx360 Electrical 2 07-09-2008 03:44 PM
