PEX Cost Compared To Copper - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-09-2010, 09:39 PM   #1
PEX Cost Compared to Copper
We are building a new house. 2600sq feet with 2 stories, 2.5 baths, laundry, kitchen, and 2 exterior spigots. What cost savings should be expected? The builder's $600 credit to go to PEX seems a few multiples low.
jbschultz is offline   Reply With Quote
Old 06-09-2010, 10:30 PM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
I don't think so. Depends on the layout of the house though.
In smaller houses where all plumbing is within 20-30 feet or so and a manifold system can be utilized, it's a lot quicker and cheaper material-wise.
When you get into bigger more spread out houses where you have to revert to typical tree/branch distribution systems, you have to cut more fittings, which = more labor, and the pex fittings cost more than a copper fitting does.
Also keep in mind that pex is not a rigid material. It requires support at more frequent intervals as well as additional blocking in the walls to keep it from moving around.
You save time and money in one area, spend a little more somewhere else... the cost difference is usually minimal. The benefit? Pex is a reliable durable plastic product that performs well in wellwater systems where copper would fail due to high acidity.
Journeyman Plumber
Old 06-10-2010, 07:04 AM   #3
Pex material cost is more expensive than copper, pex labor cost is cheaper than copper. Its usually around the same price at hte end of the day depending on the configuration, lengths and sizes of runs, so a $600 credit is not unreasonable.
The Engineer is offline   Reply With Quote
Copper re-pipe laxjtf Plumbing 11 03-08-2014 07:32 PM
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 12:20 PM
odd color copper wire macfluke Electrical 3 04-12-2009 10:13 AM
Copper pipe size question greymous Plumbing 18 01-30-2009 04:02 PM
Copper Hot Water Tank - Green Stain grover432 Plumbing 2 11-28-2005 11:05 PM
