Old 05-23-2007, 11:13 PM   #1
RippySkippy's Avatar
Default PEX with copper stub-outs
If you had a choice how would you attach the shut-offs to 8" pre-formed copper stub outs connected to PEX.
The two options I see are: compression, and sweat on. I've never been a great fan of the compression method and while I have done it in the past it seems like a hack method. While I like to sweat copper, the heat makes me a bit nervous. If I went the sweat route, what kind of a heat sink could I use to stop the heat transfer to the pex connection? A wet cloth around the copper pipe?
What do you think?
RippySkippy is offline   Reply With Quote
Old 05-23-2007, 11:51 PM   #2
I've done it with no means of cooling the pipe. As long as you're careful not to overheat the pipe, you'll be fine. If you still don't want to risk it, a wet towel will do the trick. The funny thing about those factory stubs they make...I know they tell you not to solder any closer than 16" away from a pex connection, but then they make those stubs about 12" long.
I actually like to make my own stubs with copper tubing and drop-ear 90's I stub out the wall and run the copper right down throught the plate/subfloor - it's much easier to secure and make it all come out neat that way, and you don't have that concern when you're ready to do finish.
Ishmael is offline   Reply With Quote
Old 05-24-2007, 01:52 AM   #3
That one Guy's Avatar
Commpresion will alow you to change the stop out easier down the road.
That one Guy is offline   Reply With Quote
Old 05-24-2007, 03:15 AM   #4
Journeyman Plumber
Ron The Plumber's Avatar
They make ssc copper stubs. No solder needed connect support and go.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 05-24-2007, 07:58 AM   #5
That's what I used, I'm talking about attaching the shut-off valve on the end that sticks through the wall into the cabinet area.
Old 05-24-2007, 08:00 AM   #6
True...hadn't considered that benefit...you might be on to something, it would be considerbly easier than "unsweating".
Old 05-24-2007, 08:32 AM   #7
Thanks Ishmael, your right...it's odd that they don't live by their own suggestions. Over the night I got to thinking, I could get a sharkebite connector, and after soldering pressure test that run by going to the not yet connected manifold end, shark bite the run to my pressure guage set up and monitor. If it fails....hack the wall open...ugh.....
If I would of thought this through a bit more, next time I would do as you mentioned....thanks, could you get your ideas to me quicker next time?
More On This Topic
Hey everybody Don Golden for Expert Village and we're back with copper piping and we've cleaned the inside and the outside of the pipe that we're going to be soldering today or sweating and if you're going to use this copper as a true water application... Read More »
Hey everybody Don Golden for Expert Village and we are having fun with copper today, copper piping. We just put this joint together and I felt it was my duty to show you a new technology that really makes this even easier and it is pretty easy as it is... Read More »
How to Fit Copper Pipes
How to Fit Copper Pipes by Expert Village
Hey everybody Don Golden with Expert Village and back with you on copper piping. Here are he three pieces that we are going to put together. I've got the flux and we've got our torch ready to go, dry fitted them. We know that everything is fitted... Read More »
What is Copper Sweating?
What is Copper Sweating? by Expert Village
Hey everybody, Don Golden here for Expert Village and have I got a topic for you. Okay, this is all about copper. No, not stuff you want to wear, the jewelry on your hands or wrists. It's about copper piping. Why do you care about copper piping? It is... Read More »
Hey people Don Golden back again. For Expert Village and we're working with copper pipe today. And we just finish cleaning this piece now. I want to show you how to clean the inside. We are going to use another tool. We already use the emery cloth. So, I... Read More »
brass trap to copper drain? bluebee1314 Plumbing 3 04-03-2007 12:29 AM
Pex vs copper in basement renovation Mikedks Plumbing 23 09-22-2006 04:32 PM
Questions about copper tubing... SDeeter19464 Plumbing 3 04-21-2006 10:11 AM
Copper Hot Water Tank - Green Stain grover432 Plumbing 2 11-29-2005 01:05 AM
Copper re-pipe laxjtf Plumbing 4 02-12-2005 03:21 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
