Pex To Copper Is This Acceptable - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-16-2013, 07:22 PM   #1
pex to copper is this acceptable
The plumbing in my bathroom is being change to accommodate a double bowl vanity. I've never seen anything but copper used. Is this acceptable?
marieb is offline   Reply With Quote
Old 03-16-2013, 07:27 PM   #2
Rewards Points: 1,948
Yes if you used the pex crimping tool. If not i suggest you buy a sharkbyte fitting with pex stiffeners.
Old 03-16-2013, 07:36 PM   #3
Thank you so much for responding. I am not doing this myself. A contractor is completing my bathroom. I will ask about using the right crimping tool. This will be behind a wall and I was concerned that it may not be as good as copper.
Old 03-16-2013, 07:45 PM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 664
That is a common crimping method
The Following User Says Thank You to TheEplumber For This Useful Post:
marieb (03-16-2013)
Old 03-16-2013, 10:17 PM   #5
Roofmaster
Rewards Points: 2,210
Using a hose Clamp???? No it is not acceptable.
Old 03-16-2013, 10:24 PM   #6
Plumber
Rewards Points: 664
I didn't see anyone mention hose clamp...
Granted the picture is blurry. If it is irrigation crimp ring then change it. But a normal cinch/crimp ring is standard practice.
Old 03-16-2013, 10:25 PM   #7
Rewards Points: 13,694
Look again it's not a hose clamp.
Looks like one of these.
http://www.pexsupply.com/HydroPEX-HC...-bag-3854000-p
Old 03-16-2013, 10:31 PM   #8
Plumber
Rewards Points: 664
That's what I thought too- use them all the time. One tool for 3 pipe sizes
Old 03-17-2013, 09:02 AM   #9
Master Plumber
Javiles's Avatar
Rewards Points: 996
OK E !! you don't know everything you know!
Ps... i hate that plastic stuff,,
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 03-17-2013, 10:16 AM   #10
Plumber
Rewards Points: 664
It's not my favorite either but- better get used to the stuff cuz it's not going away......
Old 03-17-2013, 11:04 AM   #11
A better picture
Hope this helps to see it better. I want to make sure before the wall gets closed back up. Thanks.
Old 03-17-2013, 11:06 AM   #12
I posted a more clear picture to see what type of clamp it is.
Old 03-17-2013, 11:09 AM   #13
Roofmaster
Tip: zoom all the way out and push that little icon of a flower. That means Macro. Its for close ups. I thought I saw a hex worm screw, sorry.
Old 03-17-2013, 11:49 AM   #14
ocd carpenter's Avatar
Yes that is a proper stainless steel crimp ring and a proper copper to pex fitting, looks a-okay to me
ocd carpenter is offline   Reply With Quote
Old 03-17-2013, 06:48 PM   #15
Thanks for the photo taking tip. Unfortunately I was using my phone and that was the best I could do. Thanks for responding.
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 12:20 PM
copper clad aluminum CopperClad Electrical 45 06-23-2012 03:21 PM
Compression fitting with copper tubing for dishwasher DK75 Plumbing 4 04-27-2012 06:47 PM
Question about copper pipe agroom Plumbing 3 10-27-2011 02:18 PM
Copper hood - Looking for input steve1234 General DIY Discussions 13 01-04-2010 01:34 PM
