Pex Connections In Wall - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-30-2009, 06:05 PM   #1
Pex connections in wall
I am doing a small remodel, and wonder on what prople are thinking of having PEX tubing connections buried behind a wall?
I myself am nervous about it , and probably won't do it.
Any comments?
thanks in advance, fred
Fewolf is offline   Reply With Quote
Old 04-30-2009, 09:16 PM   #2
Household Handyman
Rewards Points: 1,408
PEX tubing connections are placed behind/within walls every day in new construction and remodeling. Make sure all stub-outs are supported properly and if the tubing is run through holes drilled in the studs a protective plate is nailed over the hole to prevent drywall screws/nails from penetrating into the PEX. You should be fine.
Old 04-30-2009, 10:48 PM   #3
JDC
Plumbing Contractor
JDC's Avatar
Rewards Points: 262
agreed....pex connections in walls are an everyday thing
JDC is offline   Reply With Quote
Old 05-01-2009, 07:58 AM   #4
Registered User
Termite's Avatar
Not an issue at all. Your concerns are generally unfounded. Of course it is always smart to use the longest run of any kind of pipe that you can as opposed to having all sorts of fittings, but PEX fittings are reliable.
Old 05-01-2009, 10:04 AM   #5
Rewards Points: 1,910
And just like copper you want to run a pressure test before you cover it with drywall. It's just as easy to miss crimping a fitting as it is to miss soldering it.
Old 05-01-2009, 11:05 AM   #6
RippySkippy's Avatar
If you don't crimp as you go (if you use that system) when you put the crimp rings on the pipe, slide it down the pipe away from where it will eventually be crimped. That way in a glance you can tell which have been crimped and those that have not.
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 4 04-04-2017 07:38 PM
Adding drainage to existing retaining wall? pcballgame Landscaping & Lawn Care 5 04-14-2009 03:29 PM
Framing Question: How thick the wall that carries plumbing? jaes Carpentry 5 06-18-2008 05:39 PM
framing, expanding wall opening wall - load bearing? nave Remodeling 5 01-23-2008 03:44 PM
Low Retaining Wall cibula11 Landscaping & Lawn Care 3 07-29-2007 12:02 AM
