#16 |
Pex connections failing
I'm pretty sure there are no pex fitings or connection that use ferrels, I've only worked with crimp rings, and have seen a demonstration on the memory pex, are you sure it is a ferrell and not a crimp ring, the ring would look just like it sounds, and about 1/4 " in width, the ring is copper but would look darker, almost black.
#17 |
Moderator
I've never seen any sort of PEX that uses ferrules or any sort of threaded/compression connection.
Would you be able to post a picture of this? For an easy DIYer-friendly tool-less fix, take a look at the "Sharkbite" fittings. They're great for PEX as long as the connections are accessible. |
| Display Modes | |
| Wago terminals for residential line-voltage connections | BigJimmy | Electrical | 3 | 05-22-2008 02:27 PM |
| NPT Connections | Mike Warner | HVAC | 5 | 04-13-2008 12:33 AM |
| Floor beam failing? | elvinj | Building & Construction | 8 | 01-25-2008 02:33 PM |
| Stab-in connections, ceiling fans, and computers | tima2381 | Electrical | 15 | 04-01-2007 02:10 PM |
