Pex Connections - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-29-2012, 12:04 AM   #1
Rewards Points: 197
pex connections
I read somewhere that for code approval behind walls, compression sleeve connections are approved, but that crimped ring connections are not approved.
Is this just different wording for the same type of connection or are they different from each other ?
What is the difference and why are compression sleeve connections more reliable than crimped ring connections ?
Thanks,
Arky
Arky217 is offline   Reply With Quote
Old 02-29-2012, 12:10 AM   #2
Rewards Points: 626
Thanks,
Arky
With Pex You have to flare out the pex with the tool and on the pex you have a ring that slip over it before the flaring. Once that is done you quickly slip the pex pro fitting in and it will hold for ever! And the crimp is junk IMHO. and the only company that makes the best is Upinor.
Nailbags is offline   Reply With Quote
Old 02-29-2012, 12:52 AM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 358
Thanks,
Arky
Crimp rings are approved and are used nation wide. Some don't like them but I think they're the cat's meow
Old 02-29-2012, 12:54 AM   #4
Rewards Points: 12,914
Never once had a crimp ring fail.
No matter what we say your local code is all that matters. Make a call and find out.
Now, Square D Combo AFCI Breaker Trips Opens w/No Load Side Connections QO120CAFI mysterylectric Electrical 14 10-27-2013 03:51 PM
Frontier TM-619 Digital Timer connections neildawes Electrical 27 09-04-2013 09:09 AM
Meter to main breaker cable selection and connections crankcase Electrical 10 07-25-2011 12:23 PM
Asko Dishwasher Dispenser came with Different Connections momfxit Electrical 0 09-16-2010 06:33 PM
Water connections for new water heater diggerdave Plumbing 16 03-16-2009 11:36 AM
