Old 12-10-2012, 05:20 PM   #1
Pex Connection to CPVC
I will be making 1/2" PEX to 1/2" CPVC using copper crimp rings. Any recomendations on how these connections should be made? I'm looking at using a male pex to a brass female (with rubber washer) that has cpvc attached for gluing.
Is there a better connection?
natspawpaw is offline   Reply With Quote
Old 12-10-2012, 05:46 PM   #2
why not just use a 1/2" sharkbite ? have yet to see one fail
bob
bobfeather is offline   Reply With Quote
Old 12-11-2012, 07:51 AM   #3
I'm a plumber, but I've never used CPVC except to make a minor repair once on an existing system. I'm just curious - why the rubber washer? I know the PEX x male adaptor has a tapered thread (pipe thread), and I would assume the CPVC x female adaptor does also(?) If so, there's no need for the rubber washer - just some teflon tape or pipe dope. Does the washer come with the CPVC fitting, or were you planning to add it?
Edited to add: I just googled it, and saw that the washer is integral to that fitting, so you shouldn't use it with that PEX adaptor. I'd use a CPVC x male adaptor (all plastic):
http://www.pvcfittingsdirect.com/_e/...chedule_40.htm,
and a 1/2" PEX x female adaptor (brass):
http://www.pexsupply.com/Wirsbo-Upon...-PEX-x-1-2-NPT
Ishmael is offline   Reply With Quote
Old 12-11-2012, 08:51 AM   #4
Just one fitting will do it.
http://www.sharkbite.com/usa/product...&category_id=8
Old 12-11-2012, 10:51 AM   #5
Sorry to say, I feel in a diy situation a sharkbite is going to be the way to go. Plastic to brass leaks all to often if not done properly, which can be tricky.
paintdrying is offline   Reply With Quote
Old 12-11-2012, 11:13 AM   #6
And they tend to crack down the seam on the sides of the fitting.
Old 12-11-2012, 01:17 PM   #7
call me E
TheEplumber's Avatar
Why not buy a cpvc x pex adapter. They do make them
Sent from my iPhone using DIY Forum
The Following 2 Users Say Thank You to TheEplumber For This Useful Post:
Ishmael (12-11-2012), natspawpaw (12-11-2012)
Old 12-11-2012, 01:35 PM   #8
Nice! Just googled it:
http://www.siouxchief.com/Supply/Fit...-Adapter.7X8VK
That'd be the way to go.
Old 12-11-2012, 05:13 PM   #9
I didn't know such a thing existed. Exactly what I need.
Old 12-11-2012, 05:16 PM   #10
Are those sharkbite fittings really reliable? And if not for cost would you use them instead of copper crimps on pex?
PVC or CPVC pipe cement steve3847 Plumbing 7 11-17-2012 06:50 PM
CPVC connection to Delta Valve 1blkt Plumbing 0 06-27-2011 11:07 AM
CPVC Installation Questions Pittsville Plumbing 24 01-30-2011 09:38 PM
Connecting Water Filter Housing to CPVC Pittsville Plumbing 7 01-20-2011 03:01 PM
Telephone Jack Connection Problem jogan Electrical 9 04-20-2009 07:10 AM
