Old 04-15-2012, 11:04 AM   #1
PEX Connection
Which connection method is more reliable?
Yodane is offline   Reply With Quote
Old 04-15-2012, 11:24 AM   #2
Civil Engineer
PEX Connection
This topic has been discussed repeatedly on this forum, do a search for PEX connection to see dozens of threads. Some use expansion fittings (Wirsbo), some use crimp ring fittings, some use sharkbites, all have opinions.
Old 04-15-2012, 04:30 PM   #3
Homerepairguy's Avatar
PEX Connection
If a pro plumber does it, all of the connections are reliable.
If a DIY person does it, then in my opinion, the Wirsbo/Uponor PEX connection system is the most reliable.
Reason is that connections in the Wirsbo/Uponor PEX system are made by expanding the end of the PEX tubing and a PEX ring. The fitting is inserted and the tubing and ring contract around the fitting. The PEX tubing and ring contract "evenly" around the entire circumference of the fitting. All connections will be the same every time. No "go/no-go" gauge is needed to verify that crimp rings were properly crimped.
$.02,
HRG
Last edited by Homerepairguy; 04-15-2012 at 10:18 PM. Reason: Added "Wirsbo" to pex name.
Homerepairguy is offline   Reply With Quote
Old 04-15-2012, 04:44 PM   #4
PEX Connection
viega pex press it is fool proof and that is why i use them
http://www.viega.net/
be careful my advice only comes from general knowledge i know about the 4 rules it takes to plumb and they are
1 poop needs to flow down hill. 2 hot on left cold on right
3 i get a pay check on Mondays 4 do not chew finger nails at or after work.
jaydevries is offline   Reply With Quote
Old 04-15-2012, 06:13 PM   #5
call me E
TheEplumber's Avatar
PEX Connection
I use all of them. Prefer crimp rings. Lost my gauge months ago too
Old 04-15-2012, 10:07 PM   #6
PEX Connection
wirsbo pex
Old 04-15-2012, 10:58 PM   #7
Persona Non Grata
VIPlumber's Avatar
PEX Connection
They all have their pros and cons.
VIPlumber is offline   Reply With Quote
The Following User Says Thank You to VIPlumber For This Useful Post:
ben's plumbing (04-16-2012)
PVC Water Main Supply to Copper Connection jdobbs Plumbing 11 02-07-2012 12:01 AM
Dripping washing machine connection icespide Plumbing 4 11-11-2010 09:41 PM
3 way switch with pass through power connection issue ccmbee Electrical 2 09-28-2010 03:38 PM
gas dryer connection question rvegab00 Plumbing 7 12-07-2009 11:53 AM
Telephone Jack Connection Problem jogan Electrical 9 04-20-2009 07:10 AM
