PEX Clamp Tool - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-15-2012, 08:47 PM   #1
Rewards Points: 58
PEX Clamp Tool
I am going to do some plumbing in the basement using Pex-A with stainless steel clamps and brass fittings.
I need to get a clamp tool... Do these clamp tools work with different manufacturers of clamps and fittings?
Also, any recommendations on the tool itself, clamps, and fittings? I was thinking about buying HydroPex Clamps and Rifeng Fitting from pexsupply.com and then getting either the Oetiker 18038 3 handle tool or the Kobalt cinch clamp fastening tool from Lowes.. what do you think, will these tools do it for me?
Thank you,
Chris
cjdavia is offline   Reply With Quote
Old 03-15-2012, 09:18 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
Thank you,
Chris
I have the Oetiker 18038 3 handle tool and it does all sizes. Sure saves time a dollars not having to buy a tool for each size.
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 03-15-2012, 09:22 PM   #3
Rewards Points: 58
Thanks Plumber101.
Does that mean you have to use Oetiker clamps and fittings or can it work with different brands?
Old 03-15-2012, 09:30 PM   #4
Rewards Points: 560
Yes it will work with other brands.
The third handle is a little weak but it helps.
Just a tip: With the tool open it fully, then insert the crimp ring, close the tool until you hear it click ONCE and only ONCE, then slide the ring with the tool on the pex pipe, line it up and crimp
Old 03-15-2012, 09:32 PM   #5
Rewards Points: 58
Thanks for the advice and have a great night!
Old 03-15-2012, 09:34 PM   #6
Rewards Points: 560
Yep you toooooo
What tool do I need?? wholeinone04 General DIY Discussions 3 11-07-2011 08:54 AM
Clamping tool or Oscilating tool for a DIY'r-you can only pick one which would it be? whataboutj Tools 12 11-29-2010 08:12 AM
Review: Harbor Freight Oscillating Tool Tedstor Tools 0 07-13-2010 03:24 AM
Need Help with re-design ttwiss Remodeling 21 05-08-2010 11:27 PM
Fein's Multimaster Tool...don't let the price scare you! CrossWorks Tools 13 04-18-2009 07:39 PM
