Pex Cap On Copper Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-07-2011, 10:43 AM   #1
Frenchy
pex cap on copper pipe
I am removing some cabinets for a remodel job and need to cap off some copper supply lines under the sink. Is there a method where I can use a pex fitting at the end of the copper pipe or do I need to solder a copper end cap?
I am not confident enough to solder any copper fitting.
jlaricard is offline   Reply With Quote
Old 12-07-2011, 10:58 AM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
Get a Sharkbite (or 1 of their kin) cap. It pushes on and is removable. Any plumbing supply, big box or decent hardware store carries them
Coastal South Carolina
The Following User Says Thank You to rjniles For This Useful Post:
jlaricard (12-07-2011)
Heat safety during copper pipe soldering? darsunt Plumbing 9 08-14-2011 12:48 AM
replacing cast iron pipe davemarz Plumbing 1 05-20-2011 10:16 PM
Bernoulli's Principle, increase 3/4" pipe to 1-1/4" or 1-1/2" copper ChrisDIY Plumbing 14 09-18-2010 10:49 PM
Sweating copper pipe - what was I doing wrong Fortitude Plumbing 26 09-15-2010 10:12 PM
Connect 2" pvc drain to 2" copper pipe - no subfloor access missfixer General DIY Discussions 3 09-05-2009 06:44 PM
