PEX Buried Or In A Conduit? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-04-2011, 02:08 PM   #1
Rewards Points: 91
PEX buried or in a conduit?
HI:
I've completed most of the DWV installation with ABS and I have one last job to take care of before closing everything up. I can run my main water supply across the ceiling but I would prefer under the concrete floor. I was thinking of running a line of ABS and soften the last few feet to give me a gentle arc and a continuous run of about 25' under the concrete and push a 3/4" PEX feed line through that to the home run manifold.
Is this a good idea? Or, would you just bury the PEX line?
I have a bed of sand on a very hard pack glacial moraine and I'll cover the whole thing with 4" of concrete.
Allthunbs is offline   Reply With Quote
Old 01-04-2011, 02:32 PM   #2
47_47's Avatar
Rewards Points: 62
For the price of 25' of ABS, run the pex inside.
47_47 is offline   Reply With Quote
The Following User Says Thank You to 47_47 For This Useful Post:
Allthunbs (01-04-2011)
Old 01-04-2011, 02:40 PM   #3
Any time pex passes through concrete it must pass through a sleeve.
VIPlumber is offline   Reply With Quote
The Following User Says Thank You to VIPlumber For This Useful Post:
Old 01-04-2011, 04:32 PM   #4
Homerepairguy's Avatar
Rewards Points: 998
A side benefit of this is that if you have or suspect a problem with the pex line many years down the road, you could pull it out and replace it without having to break the concrete. Just that alone would make it worth running in a sleeve regardless of code. Ain't pex wonderful?...
HRG
Homerepairguy is offline   Reply With Quote
Old 01-04-2011, 06:39 PM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 830
instead of softening the pipe, consider using 2 45's or a long sweep 90. Should work
Old 01-04-2011, 09:26 PM   #6
Picky Plumber
instead of using abs why not use another different flexible pipe like black roll pipe. i'd put 3/4 into 1-1/4''. either way, i say sleeve the heck out of it
Plumber26 is offline   Reply With Quote
PVC conduit - custom offset or bending tns1 Electrical 25 08-29-2011 05:56 PM
Warm and Noisy Electrical Conduit Intravartolo Electrical 4 07-26-2010 01:46 AM
Chicago Conduit Rules Wrigleyville Electrical 6 01-28-2010 06:49 PM
distance b/ween buried conduit and water supply pipe amakarevic Electrical 4 07-26-2009 11:30 PM
driving wire through buried conduit amakarevic Electrical 26 07-08-2009 06:48 PM
