Old 03-08-2010, 11:38 PM   #1
Pex before pressure reducing valve.
I've seen this many times but is it allowed.
Rusty
rusty_5620 is offline   Reply With Quote
Old 03-10-2010, 12:24 PM   #2
Any Ideas?
Is pex allowed before the pressure regulator valve instead of copper.
Ive seen polybutyl and pex connected to the main line runnnig into the house run a few feet then connect to the PR Valve.
Cheers,
Rusty
Old 03-10-2010, 10:16 PM   #3
Doing it myself
Alan's Avatar
I don't see why it wouldn't be. Pex is allowed inside the house, so there's no reason it wouldn't be allowed outside given that it's protected from UV.
Around here the building supply is the owner's responsibility. You can use pvc or poly, but those are not allowed inside of the house. Pex is more expensive, and most people don't like that route.
Why are you worried about it?
P.S. there isn't really a standard location for PRV. Some put it at the meter, some directly after irrigation equipment, and some even put it at the side of the house or underneath.
Journeyman Plumber
How to diagnose gas valve problems Nestor_Kelebay How To Guides 27 03-07-2013 03:17 AM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 11:02 AM
Filling a Cast Iron radiator system insulatorpro HVAC 7 10-07-2008 12:31 AM
do Pressure Reducing Valve fail? wazeaz Plumbing 5 02-10-2008 06:57 AM
Pressure Reducing Valve duffers Plumbing 5 12-26-2007 05:19 PM
