Pex In Attic? - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-04-2006, 10:09 AM   #1
Rewards Points: 150
pex in attic?
Would there be any problem with running pex tubing through an unfinished attic? This may be easier to re plumb my kitchen than up from the basement. Also, is there an ProPEX fitting to link onto a piece of cut galvanized pipe?
By the way, living in Portland OR, I don't think that freezing would be a problem in the attic, but it sure gets hot up there in august
handifoot is offline   Reply With Quote
Old 06-07-2006, 08:23 AM   #2
Journeyman Plumber
Ron The Plumber's Avatar
I'm in Eugene, Oregon, you can run it in the attic, just insulate the Pipe, the pex connector is Pex x MIP adaptor, but needs a screwed connection, there is no slip connections adaptor.
Ron The Plumber is offline   Reply With Quote
Attic Smell from A/C - I'm at wit's end! cidsamuth HVAC 19 08-23-2016 05:36 AM
Ranting about attic work IvoryRing Electrical 6 04-16-2008 07:21 AM
Proper Attic Insulation reikiray Roofing/Siding 5 08-04-2007 10:59 AM
Running Romex in the attic mdalli Electrical 7 07-06-2006 05:35 PM
Air duck from basement to the attic MageMinds HVAC 2 04-26-2006 12:41 AM
